Reflective cab roof
/ Reflective cab roof #1
Mud Mechanik
Hurley, Mississippi
Massey Ferguson 1660
Has anyone put a foil like reflective roof on their cab to ease the strain on the a/c? Or do ya'll think it will even help?
/ Reflective cab roof #2
I think it would work great. Or paint it white. I used to have a white and a black peterbilt. You wouldnt believe the difference in the temp of cab when getting in them midday when neither had been used that day.
/ Reflective cab roof #3
A few years ago, Took my son to the National Trap course with his team. HOT, HOT, HOT it was. Took some Vinyl Siding core board (3/8 Styrofoam with reflective mat on one side) and attached to the black roof on the Mule 3510 Transport to haul the kids to the shooting stations that were mile long. Temperature was 10 to 15 degrees cooler under the roof with the board strapped on the top.
It does help!
/ Reflective cab roof #4
Just a thought. What about spray on insulation, the type that comes in a can? BTW, I've never used it, but I've heard of it. Best wishes.
/ Reflective cab roof #5
It works for the car winshield things. A light coloured roof or reflective material would be best. The grey roof on the Massey is alredy pretty good.
Also helps you be spotted from space if you go reflictive.
/ Reflective cab roof #7
First Tint the windows. It doesn't have to be dark to work. You could also install a head liner out of that foil backed foam mentioned in a previous post
Don't spray any foam in your cab. I have used lots of that stuff and, while it does work great, it is very messy and next to impossible to get off if it gets on anything you dont want it on
/ Reflective cab roof #8
/ Reflective cab roof #9
Be careful with the foam insulation if you use your tractor near any burn piles etc. It doesn't take much to light it up and get burned by it melting and spattering.
2017 Kubota SVL95-2S Skid Steer (A64047)
2017 Kubota...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
(4) SIDE BOXES (A63569)
(4) SIDE BOXES...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
