Redecking bridge
/ Redecking bridge #21
Real lumber yards will have 2x8 T&G available as well used for larger barns skirt boards, what is on mine. The T&G is more of a square notch on them than the wimpy round notches on the big box stores lumber.
I agree not to use them in a flat bridge deck type application though.
When I did the numbers on my Bridge Re-decking and cost of a Culvert I found my 20 something foot long bridge cost same as a good Culvert. I had access to the creek wash bottom & it is dry enough in summer/fall to scoop out the needed gravel to fill it in.
So I figured a new deck only lasts about 15 years driving over it (if that long) & guess I have maybe 25~30 years left at my place before I'm too old to care I went with the culvert and filled in the old bridge. I left the bridge in place and stuffed culverts under it, pulled loose the decking and drove out filling in buried the steel beams in the gravel. I have a thread in here some place probably 5 or 6 pages back now with a lot of pics.
Mark
/ Redecking bridge #22
I've never seen treated wood that is T&G before and was surprised that it's available. I've been trying to figure out where it would be used without any success. -------------------------------
Eddie
Mark
The square notch T&G was used for stall walls in the horse barn where we used to live. Horses can't kick a hole in it like plywood.
/ Redecking bridge
When I did the numbers on my Bridge Re-decking and cost of a Culvert I found my 20 something foot long bridge cost same as a good Culvert. I had access to the creek wash bottom & it is dry enough in summer/fall to scoop out the needed gravel to fill it in. So I figured a new deck only lasts about 15 years driving over it (if that long) & guess I have maybe 25~30 years left at my place before I'm too old to care I went with the culvert and filled in the old bridge. I left the bridge in place and stuffed culverts under it, pulled loose the decking and drove out filling in buried the steel beams in the gravel. I have a thread in here some place probably 5 or 6 pages back now with a lot of pics. Mark
As much as I would love to go with a culvert or low water crossing, it is just not feasible at this site. I must go on using the bridge and a ford for bigger stuff.
I think that I will go with non T&G, PT 2x lumber. Thanks everyone for the feedback. Hopefully I can start on a sketch soon including the new deck and wood railings. I am waiting on a quote from a welder to build the framework for 8' wide ramps for either end which will be decked the same as the bridge itself.
/ Redecking bridge #24
Eddie
The major use was for flatbed trailer decking. One of the largest producers in the country was about 30 minutes from you. We produced several hundred thousand board feet a month for companies like Omaha Standard and Knapheide. Number one lumber was treated to .60 (CCA) and the kiln charge was brought down to about 8% moisture so the wood was very dry and close to normal acclimated moisture levels for dry wood outdoors. It was then run to a T&G pattern. The result was trailer decking that exhibited minimal shrinking, warping or checking. The typical service life for the product was about 5-7 years. It wore out but did not rot out.
TLJ87, I would not use treated T&G for this use today. The Copper Azole treatment is horrid in comparison to CCA and very few companies do KDAT T&G properly as the market for it has shrunk. I would use KDAT if you can find it, the shrinking and other issues with using wet wood are greatly reduced.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2013 Toro Groundsmaster 3280D 72in. Commercial Riding Mower (A64194)
2013 Toro...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
