Recommended work lights
/ Recommended work lights #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
HI group. The sun just went down while I was in the middle of digging with my BX24. I need to order some work lights. Anyone have any favorites to recommend? I'd like a set that can swivel to point out the back of the tractor as well as the front. I'd attach them to my ROPS. I believe I have 40 amps to work with, which if my memory serves me right, would allow me to go as high as 480W total. Don't think I'd need that though.
Thanks
/ Recommended work lights #2
If I may...
Tractor Work Lights
The ROPS brackets at the top of this page are about the best thing out there for work lights. You pull two pins and you can move them around to anywhere you want. You can use any old light, but those with switches built in will be easier to wire.
bones1 said:
I have to compliment you on your website. One of the better ones I have seen,did you build it?.:)
Me or MessickFarmEquip? If me, I did build it and thanks! :)
/ Recommended work lights #5
Most of it. There are some other guys that contribute to the content. Thanks for the compliment. Its a challange to try and orginize so much data.
That's why you should outsource it to your fellow tractor enthusiast/ASP.Net MVP. :D
/ Recommended work lights #8
Thanks
A couple trap-z 55w floods should light up a huge area for ya.
Soundguy
/ Recommended work lights #9
As far as brackets go, I went to TSC and bough 2 bolt on trailer tie town bracket and with a little persuasion, they fit over the top of my rops. I then just used some metal straps and carriage bolts to hold everything together.
-Scot
bones1 said:
RayCo, are you holding up a fry or index finger in the Arbys Wheelhorse pic?:)
I believe that's a finger that's close to the index finger. :rolleyes:
/ Recommended work lights #11
If I can get back on topic without actually giving any useful information:
I have regular old 55W trapezoidal (front) and flood (rear) lights but there was a post that showed an LED worklight that was much lower power requirements. I was and am envious as I have the typical underpowered alternator.
I don't remember when the post occurred or the supplier. I told you I did not have any useful info. Happy hunting.
/ Recommended work lights #12
I picked up a coupla sets of small 50w driving lights from Zellers auto dept for about $20 a pair. This was after breaking 4 expensive ones on branches. I seldom need distance in the bush/driveway and so these work for me.
I have them set up so I can use front or rear or both, mounted high and wide as possible. Fed from a relay that gets power from ignition/aux circuit so no one(or a tree branch) turns them on and kills the battery when I'm not looking.
Husqvarna MZ61 Zero Turn (ZTR) Mower (A66285)
Husqvarna MZ61...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
New/Unused Mini...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2009 Ford Crown Victoria Passenger Car, VIN # 2FAHP71V79X128824 (A65563)
2009 Ford Crown...
