+recommended minimum temp to operate oil lube air compressor
   / +recommended minimum temp to operate oil lube air compressor #1
big bubba
Elite Member
arkansas
M8540
have a 220v single stage HD oil lube pump air compressor on a covered porch outdoors. i understand not recommended to operate in cold temps below 35-40 F? am using manu recommended syn oil type & viscosity
your thoughts? don't want to replace a $700+ 11cfm compressor, could be more now with tariffs
thanks in advance
   / +recommended minimum temp to operate oil lube air compressor #2
Me? I would make a simple enclosure for it, insulated (2x4s , OSB & Door ). Then use one of these $19 thermostats with a heat lamp. Temp low as it will go (50°).
In warm weather turn off & prop door open.
good idea. this is for my remote part time cabin, already have thermostat heat lamps for plumbing, but don't want to increase fire risk with another setup, guess i could just wait for warmer days. best regards
   / +recommended minimum temp to operate oil lube air compressor #4
How cold does it get on the porch? The main problem I see is that a little water always gets around the system. Starting a compressor cold soaked below 32F will be dealing with some frozen water somewhere(s). Above that, or if you just warm the compressor some before starting it, should be OK.
ok good point, didn't think about the moisture problem in freezing weather.
i may use heat lamp for an hour or so on the pump head before use.
   / +recommended minimum temp to operate oil lube air compressor #6
I may be the odd duck but I have never worried about using my compressor in the winter. How is it different from starting a cold small air cooled engine like on a snowblower. They are both splash lubed.
could well be. just asking since the Campbell Hausmen manual states not to operate below certain ambient temp. maybe it's overkill, regards.
   / +recommended minimum temp to operate oil lube air compressor #8
Just a crazy hair brained idea ... What about those oil dipstick heaters?
Or ... A oil pan magnetic mount heater?
You could just plug it in a bit before using it ...
   / +recommended minimum temp to operate oil lube air compressor #9
Mine is in a heated garage but I keep it pretty cold, maybe 45. It sure doesn’t sound good for when it starts for about 10 to 20 seconds. I plan on trying to preheat when I use it from now on.
   / +recommended minimum temp to operate oil lube air compressor #10
Or a synthetic air compressor oil.
I start mine at some quite cold temperature, it has run at zero F before.
   / +recommended minimum temp to operate oil lube air compressor #11
With the oil that came in my CH compressor, anything below 32dF and it would pop the breaker on start up. I replaced the oil with a 5-30 synthetic and I have run it with no issues at 15dF. Below that... I won't be in the unheated garage.
ok good, as i mentioned, i use recommended syn oii. forget whether 10-30 or 30w Mobil 1. as Spyderlk mentioned, prob could also be frozen moisture in system.
guess i'll stick with pre heating pump head when ambient temp is below freezing
apologize for overthinking, just precaution. good holiday to you all
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
(1) 48"X15' ADS DRAINAGE PIPE (A60432)
(1) 48"X15' ADS...
Bobcat A770 (A60462)
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
