2720 Specs
/ 2720 Specs #1
2Malamutes
Bronze Member
Kalamazoo, MI
As the arrival of the 2720 is "officially" coming soon, I thought I'd post the specs here so all the usual this vs. that, orange vs. green, and what still no 3 range! can commence.
Engine
Manufacturer Yanmar
Model Number 3TNV88-BMJK
Type Diesel
Gross Horsepower 22.7 kW (30.5 hp)
PTO Horsepower 17.5 kW (23.5 hp)
Cylinders Three
Rated Engine Speed 2500 rpm
Operating Range 1000 - 2650rpm
Cooling Type Liquid
Oil Filter Standard Single Element
Air Cleaner Dry Type, Two Stage
Drivetrain
Type 2 Range Hydrostatic
Number of Speeds Infinite
Mechanical Front Wheel Drive (MFWD) Standard
MFWD Capability All Ranges
MFWD Engagement On The Go
Final Drive Spur Gear
Rear Axle Maximum Load 1100 kg (2426 lb)
Front Axle Maximum Load 880 kg (1940 lb)
Electrical System
Type 12 Volt
Battery Size 500 Cold Cranking Amps @ -18?C (0?F)
Alternator 40 amp
Front Wheels and Tires
Standard 24x8.5-14 R3
Optional 23x8.5-12 R4
Rear Wheels and Tires
Standard 36x14.00-15 R3
Optional 14-17.5 R4
Front Tire Inflation Pressures (Maximum)
24x8.5-14 R3 152 kPa (22 psi)
23x8.5-12 R4 241 kPa (35 psi)
Rear Tire Inflation Pressures (Maximum)
36x14.00-15 R3 138 kPa (20 psi)
14-17.5 R4 207 kPa (30 psi)
Tire Loads
NOTE: Maximum load capacity for single tire.
Front (23x8.5-12 R4 6PR) 303 kg (667 lb)
Front (24x8.5-14 R3 4PR) 171 kg (558 lb)
Rear (14-17.5 R4 6PR) 991 kg (2185 lb)
Rear (36x14.00-15 R3 4PR) 535 kg (1179 lb)
Fluid Capacities
Fuel Tank 27 L (7.1 gal)
Cooling System 3.9 L (4 qt)
Crankcase with Filter 3.6 L (3.9 qt)
Transmission and Hydraulic System 14.6 L (3.9 gal)
Front Axle 3.4 L (3.6 qt)
Ground Speeds
NOTE: All ground speed calculations shown are with machine equipped with standard tires and operated at 2600 engine rpm.
Forward and Reverse - Range High 0-20.9 km/h (0-13.0 mph)
Forward and Reverse - Range Low 0-7.2 km/h (0-4.5 mph)
Dimensions
NOTE: Machine equipped with standard tires.
Wheelbase 1655 mm (65.2 in.)
Overall Length with 3-point Hitch 2766 mm (108.9 in.)
Overall Width (Minimum) 1196 mm (47.1 in.)
Tread Width @ Centerline (Minimum)
Front (Only Wide Position Recommended) 830 mm (32.7 in.)
Rear (Only Wide Position Recommended) 954 mm (37.6 in.)
Height From Ground
To Top of Hood 1190 mm (47 in.)
To Top of ROPS 2279 mm (90 in.)
Ground Clearance
Front Axle 330 mm (13 in.)
Rear Axle Drawbar 280 mm (11 in.)
Turning Radius
With Brakes 2.3 m (7.5 ft)
Without Brakes 2.5 m (8.2 ft)
Weight
Machine equipped with a ROPS, 3-point hitch, standard tires and all fluids. 895 kg (1973 lb)
3-Point Hitch
Type Category 1
Lift Capacity-61 cm (24 in.) behind link arms 596 kg (1314 lb)
Lift Capacity-at link link ends 650 kg (1433 lb)
/ 2720 Specs #2
so what is officially "soon" ?
/ 2720 Specs #3
A 40 amp alternater seams a little large. Maybe there is an optional factory cab for it in the future? Heat in the winter would be nice.
/ 2720 Specs
Here's a Word comparo sheet I made when I was shopping showing 2xxx series specs, and I added the 2720 known info to this point. I'll update hydraulics as they become available.
/ 2720 Specs #6
Bigtiller , it just seems there putting the heavy duty alternator
on the 2720. i have one on my 2520 , but when i bought the tractor
it was a $395 option. its good if you run 2 front and 2 rear AUX lights.
you can bet if thay put it on the 2720. it will reflect in the price....;)
Chris.....:)
/ 2720 Specs #7
The only thing i dont see is , if there just going to add a few HP .
so thay can say thay got a hafe HP more than the kubota. but dont change
the transmission or other options. what is the point. I mean my 2520 has what
26 1/2 or 27 HP and in low range. i dont run out of power ever.
I over power the tires before the motor. it just spins in 4WD...:rolleyes:
as far a lift , it lifts as much as the machine can really move safely.
I proved that. so where is the great binifit at. you know its going to cost more.
Maybe i am missing the point....:confused:
Chris....:)
/ 2720 Specs #8
In your comparo sheet, it shows the 2520 with a 40 Amp alternator. Is that correct or is it a typo? I've seen 40A listed on some info the dealers have printed out for me, but on the brochures it shows 20A
/ 2720 Specs #10
Chris,
I suspect the main reason for the 2720 is to provide a machine to compete numerically better with the B3030 Kubota and also provide a machine that can give better PTO performance while in high range. I know for me, having had three different mid frame machines (4310 and two 3720's) the 3720 would do nothing more than would the 4310, but on my hilly terrain I found myself using A range almost all the time with the 4310, where I used B and sometimes C with the 3720. I have briefly used a 2520 on my terrain and really could do no meaningful work in B range. I think for someone like me the additional four horses and few lb feet of torque would really help. This does not really apply as much to those who live in flatter areas, as all these machines have ample power.
John M
/ 2720 Specs #11
Look at the bright side Chris2520, Kubota gave us a nice three speed hydro, and kept the tiny little loader bucket with no quick change options, and no position control on the 3pt. Sometimes it seems that both companies are more intent on playing games with each other than they are about giving us really functional machines. They seem to keep things just unbalanced enough that we have to choose this, or that, and can't have both with either color machine. I guess that does keep us all from making intelligent comparisons, or comparing apples, and apples. It's frustrating when we are trying to spend that much money on something we can live without, but will make life a lot more fun, and productive.
/ 2720 Specs #12
jcmseven said:
Chris,
John M
John , you may be right on the PTO power. but i still ant seeing it.
i dont care if it had 35 HP a 2520 or 2720 is not going to do any PTO or loader work in high gear. Trust me. i am the fore most authority on this.
after owning it for a year and all the things i done. i been in high gear
only a few times. and that was to Boogie down the street. high gear is just geared to high for any work. The thing runs 13 or 14 miles an hours.:rolleyes:
when i get on the road , it think i am going to pass some cars..:D
it needs a B range. and the extra HP would be good for PTO work.
until then it ant really going to matter. unless you are rideing around on
something as flat as a golf couse.....;) Thay dont give you a 3 range. cause
thay want you to spend more money and get a 3000 seris.
Chris....:)
/ 2720 Specs #13
Chuck , there trying to compeat with the kubota 3030
and it does have position control and a quicktach option
but it has a 3 range transmission. thats what i am saying.
Chris....:)
/ 2720 Specs #15
MessickFarmEqu said:
Is this tractor going to be on a larger frame than the 2520? Its still a bit physically smaller tractor right? More the size of the B2920?
Neil , the 2520 is acualy a little larger tractor than the 3030.
I drove a 3030 and the 2520 has a little larger feel to it.
also a 2520 weighs more than a 3030. See thats what i dont understand.
if the 2520 or the 2720 had a 3 range hydro. there would not be anything to
compete with it. it much more comfortable tractor to drive. than the bota.
like i said. i dont think JD wants to put a 3 range in the 2720 , cause it would cut into there 3000 seris sales. witch is a more expensive tractor...:(
Thats my thinking and i am sticking to it.....:D
Chris...:)
/ 2720 Specs
I went off the 2008 2520 specs on JD's website. As far as whether that is accurate or not I do not know.
/ 2720 Specs #17
Chris,
I think you are mostly correct. The John Deere marketers do not want to detract from their 3000 series sales. But, as you know, those of us that buy a 2000 series machine mainly because we NEED a machine of that size. The 3000 series JD machines are some larger, but a lot heavier. True, JD might lose some sales if the 2000 series has three ranges, but for the most part those buying a 3000 series machine would do so for its heavier lift capacity and increased chassis weight/attachment capability.
John M
/ 2720 Specs #18
I think Deere should put the 3 range trans in the 2520 and maybe the soon to be 2720 and eliminate the 3120 alltogether. Dont really see to many 3120s out there.
/ 2720 Specs #19
Why does everbody hate on the 3120? I'll take my much maligned 3120 with the 300CX over anything in the 2000 class.
/ 2720 Specs #20
Thebigc , there is nothing wrong with the 3120. i think what he is trying
to say , is the 3120 is to close to the way more popular 3320. deere dont sale very many 3120's my dealer told me that. cause for very little more you
can have a 3320. now with the 2720 comeing out. there will be a 2000 seris with more HP than the 3120. so yes is needs to go.....;)
Chris....:)
Baby Goat Decorative Statue (A66738)
Baby Goat...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
2005 John Deere 225CLE Hydraulic Excavator (A66734)
2005 John Deere...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
