2720 Specs
/ 2720 Specs #41
This is just a guess, but I suspect the reason for the three range preference is that the range selector gearbox is downstream of the hydrostatic motor.
I think folks are saying that in the JD high range, the diesel/hydrostatic system has to work too hard because there isn't enough gear reduction, whereas in the low range the diesel/hydrostatic can't drive the tractor fast enough because there's too much gear reduction.
Someone smarter than I needs to weigh in on this.
/ 2720 Specs #42
I'm no expert but maybe the HST ranges can be compared to a geared bicycle. You can put the bike in high gear and go from 0 to 30 mph but it will be quite difficult if you have to climb a hill at 5 mph in high. It's much easier to change to a lower gear. The tractor in high gear would have the same problem. Even though you have infinitely variable speeds from 0 to 14 or so mph in high range, the power required to go, say, 4 mph is greater in high range than in low range because of the different gearing.
Back to the 2720, would y'all agree it's a modernized replacement for the 955? About the same weight, power, standard MFWD, 2 range HST...
/ 2720 Specs #43
The gear choices are the same 'cause they keep re-using the SAME Kansai transaxle. I imagine it is very painful to start over designing with a new transaxle, since it is the basis of the tractor. Many new parts, very little re-use, more expensive. My 2520 has the same trans as my old 4100 had, and it appears (at first glance, from your descriptions) they re-used it again on the 2720. Now, if only it had a hi-low range shift on the go, added to the current two-speed range set, and hydro of course, you'd really have something.
1998 GMC SIERRA 1500 (A67714)
1998 GMC SIERRA...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
Unused 2024 HLA MB48 48in. Bucket Skid Steer Attachment (A66734)
Unused 2024 HLA...
ALLMAND MAXI-LITE II V-SERIES (INOPERABLE) (A68842)
ALLMAND MAXI-LITE...
1988 BOMAG BW-213PDH-2 SHEEP FOOT ROLLER (A67714)
1988 BOMAG...
