Reclaiming Field Perimeters 101
   / Reclaiming Field Perimeters 101 #21
Not far from NC line. About the middle of the VA. Don't hold out on me DT86. What do you know?
Sounds like you're near me (Boydton).
   / Reclaiming Field Perimeters 101 #22
I use an Echo pole saw but it is real hard on the arms.
   / Reclaiming Field Perimeters 101 #23
Not Lazy. I have done that too. I just keep getting hit in the head from the ones that don't break all the way and whip back across the tractor. :banghead: This may be a standard practice, and the way I keep doing it at times.
Thanks for the feedback.
If I have something that doesn't want to come off all the way, I whack it with the bucket a 2nd or 3rd time. I've always been able to get them to come off completely. I usually put the teeth or cutting edge of the bucket on top of the branch and push it down so if it does whip back, it whips up a little. Those that do that I either push down again or push them forward, whichever looks like it will work best for that branch.
Now I still have little crap from the sides that will whip in but with long sleeves and gloves, I tend to stay pretty much in tact.
   / Reclaiming Field Perimeters 101 #25
These forestry clearing saws will cut a lot of stuff and much easier than bending over with a chainsaw.
Object moved
I have the FS 350 model with a brush/weed blade, chainsaw type blade, and a normal saw kerf blade. They come with a shoulder harness that supports the saw's weight. 2"-3" trees are no problem for mine. I use it to keep walking trails too narrow for the tractor clean. It's my lawn grass whipper too with a string head.
Judging by what the 350 model can do, the 560 would be a serious cutting machine. They are used by forestry crews to thin tree stands and remove unwanted species.
   / Reclaiming Field Perimeters 101 #27
   / Reclaiming Field Perimeters 101 #28
Look at JJ's post on the Forum: Attachments page "Hydraulic Limb Snipper" for a homemade version. Sadly, I don't have a shop, a welder or a skill set adequate to do this kind of fabrication.
Bob
rd,
This would be great.
I wonder if there is a similar production model out there, without the really long boom?
Bob
   / Reclaiming Field Perimeters 101 #30
rd,
Hydraulic Limb Clipper to fit Bale Spike on Front End Loader
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
Quick Attach EZ Axe Skid Steer Tree Shear (A52128)
Quick Attach EZ...
