Rear work light
/ Rear work light #1
ArkCivEngr
Russellville, Arkansas
Kubota L3400DT, John Deere X495
Any ideas what a rear work light kit would cost for my L3400DT? Also:
1. Does the light kit require a beefier alternator than the one that came with my tractor?
2. I assume the light(s) mount on my ROPS. Are they QA, or permanent?
Thanks in advance for tolerating (and hopefully curing) such ignorance. /forums/images/graemlins/grin.gif
/ Rear work light
/ Rear work light #3
I think it is already wired for it. Look under the rear fenders there shoud be a couple of wires that are hot when the key is on. There is a hole in the fender there also. I don't have a light mounted yet, but plan to add one I bought at Walmart along with a switch. Just haven't had the time. The hole seems like a natural place to add it, not sure where the switch will go. I may make another hole beside it and mount the switch there.
/ Rear work light #4
/ Rear work light #5
As has already been said. You should have a wire under the seat or fender for the work light. I bought my light at TSC. There was a hole in rear fender sheet metal to mount the light. It is permanent and has it's own switch in the light housing. See attached picture.
/ Rear work light #6
/ Rear work light
Thanks guys. I'll look for that. Any particular size (wattage) light that I should aim for, so as not to strain the alternator?
/ Rear work light
/ Rear work light #9
Does anyone know if a B3030 is similarly pre-wired for rear work light(s)? Thanks
/ Rear work light #10
/ Rear work light #11
Kubota makes lights (I believe 35w) and mounting brackets with U bolts bent to go around the ROPS. Sorry, I don't have the part no's . The fit very well but two lights and brackets are about $180 to buy and are easy to install.
/ Rear work light #12
/ Rear work light #13
here is a photo of the lights described above
/ Rear work light #15
</font><font color="blue" class="small">( here is a photo of the lights described above )</font>
I have one of these on my BX22. It's been there 4 years and has been abused - still going strong!
Terry
/ Rear work light #16
Terry
/ Rear work light
OK, I checked it out this morning. In each fender, there is a small hole slightly in front of where the flasher is mounted. The wiring underneath consists of a typical harness running to the flasher, but also has two wires that dead-end. One is black, the other yellow. I assume these are the "hot" ones referred to.
Looks like it should be a simple operation to wire up and attach. I'd like to put lights on both sides. Is that what was intended? Will the alternator handle it?
/ Rear work light
/ Rear work light #19
</font><font color="blue" class="small">( Does anyone know if a B3030 is similarly pre-wired for rear work light(s)? Thanks )</font>
Sure is pre-wired. The wires are tucked up TIGHT under the right rear flasher light( right side aft looking fwd) You'll find the grn wire with a ring terminal and the hot wire already has a quick disconnect crimped on it.
/ Rear work light #20
2022 EZ-GO ELITE...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
Sakai SW354 (A64126)
Pat's QH and hydraulic top-link.
Pat's QH and...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
Ford N Series Tractor (A66285)
Ford N Series...
