Rear work light stock wiring
/ Rear work light stock wiring #1
JD 4520
Platinum Member
Snohomish County WA
John Deere 4520
On my 4066R, I have installed the JD rear work lights, however, I can only locate the stock wire for the right side. I have not been able to locate the left side (rear) wire. I know it should be purple and black, so I know what I am looking for, but just can’t locate it. Any suggestions?
/ Rear work light stock wiring #2
On my 2009 Kubota M6040 there was only one hot lead - on the right side. Wonder if that is the same case on your JD.
/ Rear work light stock wiring #3
Only one hot lead for the work lights on my 4300, and suspect that may also be true for the OP. The switch for power only has one position and not a right and left position for two work lights. Hope these ideas help.
/ Rear work light stock wiring #4
You may have to wire them together using a "Y" connector. I did that for wiring two LED work lights on my Gator. Both lights are operated by one switch.
The cab tractors (4xxx series) do have four work lights...two forward, two aft...all controlled by one switch.
Another thought is asking you local Deere dealer service department the best way to wire them...
/ Rear work light stock wiring #5
LVA10595. This is a single to dual pigtail.
Probably easier/cheaper to make your own.
2009 CHEVROLET SILVERADO 3500 TOW TRUCK (A65057)
2009 CHEVROLET...
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2025 44in Single Cylinder Grapple Rock Bucket Skid Steer Attachment (A66734)
2025 44in Single...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
24 FOOT ROLL OFF DUMPSTER (A67714)
24 FOOT ROLL OFF...
