Rear Work Lamp Options
   / Rear Work Lamp Options #1
tderrick
Nashville
L3901 , Ford 8N and 640
The 8N is finally retired and placed onto the restorative back burner along with the 640 Red Tiger. A brand new 3901 has arrived with loader, hay spears and cutter.
Life is good.
I passed on getting a factory installed rear work lamp and decided to research options myself.
Any ideas?
thx
I found a thread on google to this forum that i didn't find in local search. I have enough ideas to get me going. If anyone has any new info , I will appreciate the input.
thx
   / Rear Work Lamp Options #3
Well Congrats on the new tractor....
   / Rear Work Lamp Options #4
You can get some led lights and put them on the ROPS ......
   / Rear Work Lamp Options #7
Ya or you can just make your own set up...I have a light bar facing front and 1 round facing rear..........
   / Rear Work Lamp Options #8
I used some PVC pipe pucks as spacers & clamped a pipe over my ROPS. Drilled holes in that bar & put generic LED cubes on it. I wanted to securely mount things but not modify the ROPS. Was some random towel rack square pipe or something & a couple square U bolts so dead easy.
Forget where I wired it to, under the dash somewhere as I put a switch on the dash. All the Kubotas have a ignition switched plug under the left (standing behind looking forward) fender. Its 10 or 15 amps, plenty for 4 LED cubes.
The plug is either the male or female Original 2 pin Power connector for VHF/UHF Power cords - Power source side | Powerwerx. Common ham radio plug, but it's hard to figure that out & not well documented. You still need a switch or 2 if you use that circuit. IMG_20140209_110007-3.jpg
   / Rear Work Lamp Options #9
Ebay for led lights made my own switch bracket..........l3800 light bar.jpgl3800 light switch 2.jpg
   / Rear Work Lamp Options #10
81mm Round Magnet
I used these magnets to mountfront and rear LED lights on BX (volts/watts = amps) a 5 a watt light = (12/5) 2.4 amp fuse or 5 amp for pair of lights. You could run from lighter socket or wire to switch/fuse/battery.
Made something more elaborate For the B
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
2011 Audi Sedan (A56859)
2011 Audi Sedan...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A57453)
2014 Ford F-150...
LAWN AERATOR (A52708)
