Rear weights
/ Rear weights #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
Can anyone tell me the diameter of the 52# starter weight and 110# standard weight that would be used ona JD 3x20 series with R4 tires? I have also noticed pictures people have posted showing a flat sided standard weight but JD parts shows a slightly domed weight with notches on the edge. Which one is right?
/ Rear weights #2
The 55lb (25kg) weight is for the R-4 tires, regardless of large or small R-4. The flat weight is the correct one and the one depicted on their JD 3x20 operational videos, mostly with 2 weights installed per side.
The domed 110lb weight is intended only for the R-1 Ag rims/tire combinations with removable center disk. These rims are much larger in diameter than the R-4's.
JD parts will show all available parts for the section in question (wheel weights) but not all are correct for every application. Even the hardware is labeled for use with specific weights only (110, 55, starter, addon). The parts section is intended for folks looking for replacement parts and thereby presumes you know what you require.
If you have R-4 tires, the 25kg (works out to 55.15lb) weights ARE the correct ones. The 110lb ones simply won't work as their diameter is way too large for you.
/ Rear weights #3
Radman. if you do a search for NYBOB post of "Wheel weights for 3720" you will find some pic I posted of the weights on my 3520 and also some pics Superduper's weights on his tractor. It will help you see what you need. Superduper is 100% correct about the scalloped shaped weights............they will not fit the R-4 wheels.
Sincerely, Dirt
/ Rear weights
Thanks for the heads up. You guys know more than me or my dealer. I don't think they have sold any of the rear weight kits for the smaller rims. they are mostly ag tractor dealers.
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
Mini Skid Steer (A60352)
Mini Skid Steer...
2017 Ford Box Truck (A62613)
2017 Ford Box...
2013 Ram Caravan (A61574)
2013 Ram Caravan...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
