Rear tire chains on 3520
/ Rear tire chains on 3520 #1
LHS Inc
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
Are chains a good fit on the '10 3520 rear R4 tires? Do they clear the fenders safely? We don't get alot of snow in a normal winter here on the Eastern Shore of Maryland but after last year's 3 big storms I want to be prepared for the worst.
/ Rear tire chains on 3520 #2
Hi,
We use chains on a 3320 with the stock smaller R4s and wheels set at their widest & the chains clear the fenders with no problem.
The chains have a side to side (ladder type) chain every 4 links on the circular inner and outer chains. They are available every 2 links but the 4 link works fine for us & is quite heavy.
Although JD says they are not needed I added the spring loaded tightener (spider) to take out some of the slack in them.
The front chains also from JD are cross chain every 2 links and need the tightener to keep from "walking" out of the chains.
They will pit your concrete drive or garage floor but on the ice we get in the notheast they are needed.
We got our chains from the JD dealer but I think that they got them at Tire Chains by TireChains.com which is where I got our spiders.
Hope this helps
/ Rear tire chains on 3520 #4
I doubt you'll see enough snow to justify chains. Also, the Eastern Shore areas I'm familar with are pretty flat (little sloping).
Tirechains.com recommends a minimum of 2.5" clearance before installing the chains. Use your hand or a tape measurer to see what you have.
If you don't have adequate clearance, I'd suggest swapping those rear tires side to side (if the wheel offset allows it) before installing spacers.
The 3x20 series machines (with R-4's) I've looked at appeared to have plenty of clearance as delivered, BTW.
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
3145 (A63117)
3145 (A63117)
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
2014 Mercedes-Benz GL 450 4MATIC AWD SUV (A61574)
2014 Mercedes-Benz...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
