Rear Roller
/ Rear Roller #1
scott_vt
Super Member
east wells,vt
1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
I have an old 100lb propane tank that I was thinking about converting into a rear roller to pull behind the tractor, probablly just rig up something to the drawbar. I believe its about 12 to 14" in dia and about 5ft long maybe slightly more.
Have any of you guys used one of these like that or does someone have a better suggestion? Thought I could put a pipe through it and fill it with water. Any ideas? Any pictures?
scotty
scotty
/ Rear Roller #2
I did something similar to that, but filled it with concrete. Then built a steel rack above to add 400 more pounds so have about a pretty heavy roller. It is non too heavey for doing a decent job of rolling. Mine is 48" long, and I wouldn't want it any longer. I roll in the spring when the frost is out, but before the ground settles and dries. I don't think water alone will give you enough weight to do much rolling. But it is handier to move around without the water.
Getting about 10" of snow now, so no pics as of the moment.
/ Rear Roller #3
Not sure where the thread is, but someone on TBN used a propane tank to make a roller. I thought it was a great idea. If I remember correctly the propane tank was much bigger than a 100 pounder. The person gave quite a bit of information on how he put it together as well.
Let us know how it goes and take a few photos.
Farwell
/ Rear Roller
Thanks Beenthere,
Just curious, did you rig yours up to the 3pt hitch or do you just tow it with the drawbar?
The concrete and extra weight sounds like a good day. I think I could find a fair amount of work for it, including rolling the drive after grading.
Thanks Again,
scotty
/ Rear Roller #5
I found the thread on the propane tank roller:
Re: Underground propane tank [Re: Junkman]
#691281 - 07/12/05
Not sure if I did this right in cutting an pasting the information but if you can't get to the thread easily, just go to the search box and add Underground Propane Tank.
Farwell
/ Rear Roller
Thanks Farwell,
Everyonce in awhile I have brain fade and forget about our search engine /forums/images/graemlins/confused.gif
scotty /forums/images/graemlins/grin.gif
/ Rear Roller #7
HI Scotty, I think if you use concrete it will be quiet rolling on the drive if its full of water it will make lots of noise rolling on the gravel... One way to find out for sure is try the water first, then just add the sakrete and take it for another ride /forums/images/graemlins/smirk.gif sand also works...
/ Rear Roller #8
Living in Vermont you may want to add a little anti-freeze to your roller if you go the water route for weight or drain it during the cold season. Had a plastic roller and found out the hard way that water expands when frozen. Very dumb on my part.
Good luck.
Farwell
/ Rear Roller #9
Whatever you do, be really careful if you are going to cut and weld on that propane tank. No matter how empty they are, there can be residual flamables inside. The best thing you can do to prep one for welding is remove the valve assembly completely. Then, get a good brush pile fire going and throw the tank in the fire. This will burn off any residuals, and make ti safe to work on. Good luck, and be careful.
/ Rear Roller #10
Scott
This is just a roller, and has a Y for a hitch (pulled it originally with my 8hp wheelhorse). It covers the width of the lawn tractor tracks.
I too thought it would work packing the driveway down, but my neighbor who worked for the county said that it wouldn't work (and he was right, it didn't). Much better packing to drive the car or truck on the freshly laid/spread gravel to pack it good. More psi than the roller can give. One stone in the gravel will raise the entire roller because the stone wont break nor will it push into the gravel below, thus it doesn't pack anything that is below the height of that one stone. But you can learn that by trying it, as that is what I did. /forums/images/graemlins/tongue.gif Then I believed it. /forums/images/graemlins/smirk.gif
/ Rear Roller #11
But it will smooth the drive considerably, if rolled while moist & soft, with large enough roller. Mine is 3' dia x 6' long, filled with concrete. Will suprise you how many gravel it will push down flush with the others.
/ Rear Roller
Mornin Arbo,
Thankyou very much for mentioning just that. I was very aware of just that problem but really didnt know the best way to rid the cylinder of that residue. It just so happens that I do have some brush to burn, which I can pile out in the middle of the field and do just that!!!
Now darn, if I only had a grapple to move the brush /forums/images/graemlins/grin.gif
scotty
/ Rear Roller
Mornin Mark,
Thats a good thought, I dont know how fancy I want to get with this thing. Im almost tempted to rig up a 3pt setup with some type of frame that I can hang additional weights on as someone else mentioned. We are only at the drawing board right know. /forums/images/graemlins/grin.gif
scotty
/ Rear Roller
Thanks for posting that link, some real good ideas in that post. Maybe its time to visit the local gas companies for some throwaways /forums/images/graemlins/grin.gif My 100lb is lookin way too small /forums/images/graemlins/confused.gif
scotty
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
INSPECTION (A65579)
INSPECTION (A65579)
Pallet Racking Uprights (A62613)
Pallet Racking...
7x16 Enclosed Spray Foam Trailer (A65563)
7x16 Enclosed...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
