Rear remotes
/ Rear remotes #21
If your hyd block looks similar.
If not, there are ways to connect things up in a logical order.
Show us some pictures of your hyd block.
What type remotes are you wanting to install?
How many spools?
L2800 hyd
Hydraulics:
Type: open center
Capacity: 7.3 gal [27.6 L]
Valves: 0 to 3
Pump flow: 6.8 gpm [25.7 lpm]
Total flow: 11.1 gpm [42.0 lpm]
Steering flow: 4.3 gpm [16.3 lpm]
/ Rear remotes #22
Looks like I have the same block. I will be paying attention.
L2800 w/FEL - 72" Land Pride rake
/ Rear remotes #23
Sorry, didn't answer all questions. At this point I have no plans or need. I am in learning mode.
/ Rear remotes
Hang in there, buddy. I'll ask the dumb questions and we'll get through together.
/ Rear remotes #25
Yours is the same and well be plumped the same. Real easy to do. The hard part is where you want to mount your valve.
/ Rear remotes #27
From what I remember the green one is Power beyond, and you take it loose, and put it in the input of your valve stack and the output/PB of you valve stack goes back to where you just took the green fitting off of. and the tank gets "teed" into the gray one. Like I said that is what I remember, but don't quote me:)
James K0UA
/ Rear remotes
All,
You have gone to a lot of work to pull together all this information and I greatly appreciate it. Maybe one of you with more computer literacy than me can figure out how to keep it together in a single file so it will come up on a search. It would be a shame to have to go through the whole process again when the next guy asks the question.
I ordered the valve and PB yesterday afternoon. I will document with photos and as much detail as necessary the installation but it will be a long process. I usually get home every other weekend but I'm usually pretty busy catching up on stuff around the place.
Thanks again for all the help.
/ Rear remotes #30
Save this picture in your picture folder.
The Kubota tech at Kubota dealership told me that a good many tractors use that configuration.
He said there is also another way to connect additional ports, but I will have to check on that setup.
If only the manufacturers would show a hyd diagram with every tractor, it would be a big help in figuring things out.
/ Rear remotes #31
Looking forward to the pictures DLG. Thank you all for the information.
2025 Grapple Mini Excavator Attachment (A61572)
2025 Grapple Mini...
SUPER C PNEUMATIC GUILLOTINE SAW (A64281)
SUPER C PNEUMATIC...
UNUSED AGT MX-MRW14 STAND-ON SKID STEER (A64280)
UNUSED AGT...
1993 EAST 102" X 48' SPREAD AXLE FLATBED TRAILER (A64276)
1993 EAST 102" X...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
