Rear remotes
/ Rear remotes #21
If your hyd block looks similar.
If not, there are ways to connect things up in a logical order.
Show us some pictures of your hyd block.
What type remotes are you wanting to install?
How many spools?
L2800 hyd
Hydraulics:
Type: open center
Capacity: 7.3 gal [27.6 L]
Valves: 0 to 3
Pump flow: 6.8 gpm [25.7 lpm]
Total flow: 11.1 gpm [42.0 lpm]
Steering flow: 4.3 gpm [16.3 lpm]
/ Rear remotes #22
Looks like I have the same block. I will be paying attention.
L2800 w/FEL - 72" Land Pride rake
/ Rear remotes #23
Sorry, didn't answer all questions. At this point I have no plans or need. I am in learning mode.
/ Rear remotes
Hang in there, buddy. I'll ask the dumb questions and we'll get through together.
/ Rear remotes #25
Yours is the same and well be plumped the same. Real easy to do. The hard part is where you want to mount your valve.
/ Rear remotes #27
From what I remember the green one is Power beyond, and you take it loose, and put it in the input of your valve stack and the output/PB of you valve stack goes back to where you just took the green fitting off of. and the tank gets "teed" into the gray one. Like I said that is what I remember, but don't quote me:)
James K0UA
/ Rear remotes
All,
You have gone to a lot of work to pull together all this information and I greatly appreciate it. Maybe one of you with more computer literacy than me can figure out how to keep it together in a single file so it will come up on a search. It would be a shame to have to go through the whole process again when the next guy asks the question.
I ordered the valve and PB yesterday afternoon. I will document with photos and as much detail as necessary the installation but it will be a long process. I usually get home every other weekend but I'm usually pretty busy catching up on stuff around the place.
Thanks again for all the help.
/ Rear remotes #30
Save this picture in your picture folder.
The Kubota tech at Kubota dealership told me that a good many tractors use that configuration.
He said there is also another way to connect additional ports, but I will have to check on that setup.
If only the manufacturers would show a hyd diagram with every tractor, it would be a big help in figuring things out.
/ Rear remotes #31
Looking forward to the pictures DLG. Thank you all for the information.
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2017 Chevrolet Equinox SUV (A61574)
2017 Chevrolet...
2017 Forest River Rockwood Freedom Camping S/A Trailer (A61574)
2017 Forest River...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
