3-Point Hitch Rear remotes B2320
/ Rear remotes B2320 #1
displacedPA
SC
NH T2310
I priced the remote kit from kubota and Im not willing to pay the 700.00. I have a top link and a valve picked out from surpluss center but I want to make sure Im getting the right valve..does someone have a spec sheet from the kubota kit that shows what the valve configuration is?
below is the vavle that I would plan on using...
Surplus Center - 1 SPOOL 8 GPM PRINCE MB11C5C1 MOTOR SPOOL VALVE
I plan on using this set up for a hyd top link and a log splitter setup.
thanks in advance
I suppose this is my real question,
Does someone have a diagram of the factory B7309 remote kit install instructions? :confused:
/ Rear remotes B2320 #3
Sorry, I can't answer your question but you might have more luck posting the same question in the Hydraulics forum.
Thanks I moved it to the hydro fourm...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
2022 Horizon (A55973)
