Rear remote coupling plate
/ Rear remote coupling plate #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Hey guys I'm getting ready to add a bunch of hydraulic remotes to my tractor and i was curious if there are special couplings that are needed to mount the rear remote connections into a plate, unless i just need to find couplers with male threads and lock them down with nuts into a plate I make, or do they make nuce clean blank plates also, I hope to be getting my mahindra backhoe for my 2538 this week and then I'm sure I'll have more questions since I plan on plumbing in backhoe feed and a 2 spool rear valve and maybe even a 3rd function, thanks
/ Rear remote coupling plate #3
Kubota supplied these with my L4330 "kit". Nice solid cast iron "sockets" with a heavy steel mount bracket that mounts to the rear up under the toolbox. Pioneer quick connects inside with a big snap ring in the back to secure them.
Nice and neat, but pricey!
/ Rear remote coupling plate #6
As JRobyn posted, Kubota makes rugged cast iron coupler housings stackable against a plate which could be mounted in several locations.
The are indeed pricey.
It is recommended you use "break away" type couplers for rear remotes in case you forget to uncouple a hose when removing an implement.
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2005 STERLING LT9500 SERIES HYDROVAC (A67714)
2005 STERLING...
3097 (A63117)
3097 (A63117)
X (A68191)
X (A68191)
Fuel Storage Tank (A68134)
Fuel Storage Tank...
