Rear remote coupling plate
/ Rear remote coupling plate #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Hey guys I'm getting ready to add a bunch of hydraulic remotes to my tractor and i was curious if there are special couplings that are needed to mount the rear remote connections into a plate, unless i just need to find couplers with male threads and lock them down with nuts into a plate I make, or do they make nuce clean blank plates also, I hope to be getting my mahindra backhoe for my 2538 this week and then I'm sure I'll have more questions since I plan on plumbing in backhoe feed and a 2 spool rear valve and maybe even a 3rd function, thanks
/ Rear remote coupling plate #3
Kubota supplied these with my L4330 "kit". Nice solid cast iron "sockets" with a heavy steel mount bracket that mounts to the rear up under the toolbox. Pioneer quick connects inside with a big snap ring in the back to secure them.
Nice and neat, but pricey!
/ Rear remote coupling plate #6
As JRobyn posted, Kubota makes rugged cast iron coupler housings stackable against a plate which could be mounted in several locations.
The are indeed pricey.
It is recommended you use "break away" type couplers for rear remotes in case you forget to uncouple a hose when removing an implement.
12ton Hydraulic Bottle Jack (A64557)
12ton Hydraulic...
2021 JOHN DEERE 333G SKID STEER (A65056)
2021 JOHN DEERE...
2011 Lexus IS250 Sedan (A66738)
2011 Lexus IS250...
2015 CATERPILLAR 525D DUAL ARCH GRAPPLE SKIDDER (A65056)
2015 CATERPILLAR...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
2013 International DuraStar 4300 S/A Dump Truck (A66736)
2013 International...
