Rear Remote CK 20H
   / Rear Remote CK 20H #1
Mike O
Vancouver Island BC
CK20 HST 2007
Seasons Greetings: I am having issues with the hydraulics on my 2007 Kioti CK20H; the engine starts to bog down when the Remote Control Valve Lever is in either position A or B. I forgot to move the lever back to N after using a rear mounted hydraulic implement; used the tractor for about an hour with the rear hydraulics deadheaded and the PTO engaged. Tractor started to overheat and run rough, but I caught it in time. The tractor runs fine and both the FEL and PTO implement operate ok (not using rear hydraulics) in the N position however I need to engage the B position to power the log splitter. Any ideas? Thanks.
   / Rear Remote CK 20H #2
If you have another implement or cylinder that doesn't have a separate valve I would want to see if it still loads the tractor. Might even use a hose with nothing attached and see if you are even getting flow out of the valve.
It could be something simple like a bad coupler on the tractor or splitter.
Good luck and Merry Christmas!
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
KUBOTA M8540D TRACTOR (A60430)
KUBOTA M8540D...
2016 GENIE S65 TELESCOPIC BOOM LIFT (A60429)
2016 GENIE S65...
2024 KAUFMAN LOPRO WEDGE 3 CAR TRAILER (A59905)
2024 KAUFMAN LOPRO...
