Rear Hydraulics
/ Rear Hydraulics #41
Good job on those brackets. A little MF mirror black paint and you will be fixed up.
/ Rear Hydraulics
Hey Jerry - What would you think of drilling and tapping the front cross piece of the loader to mount my front auxilary bracket?
/ Rear Hydraulics #43
How about using the center tube hold down bolt. That one bolt would do it if you had a plate under it that had a lip over hanging the front or back of the beam. Then have your QA fitting mounted to that plate. Clear as mud? /forums/images/graemlins/crazy.gif
/ Rear Hydraulics
I think I get what you're driving at; the lip would prevent twisting with just the one bolt holding it, correct?
So, are you saying you wouldn't drill/tap into that cross piece?
/ Rear Hydraulics #45
<font color="blue"> I think I get what you're driving at; the lip would prevent twisting with just the one bolt holding it, correct?</font>
Yes, that is why I would put the lip in.
<font color="blue">So, are you saying you wouldn't drill/tap into that cross piece?</font>
No, not at all. I don't think that it would hurt anything to drill and tap it. I just always try to use existing fasteners when I can if they prove to be in a good location.
/ Rear Hydraulics
Auxiliary hydraulics update: I’ve got the rear ones mounted and they are working fine. I plan to finish the front set and get a photo of it tonight. I’ve got the dust covers on order as well.
/ Rear Hydraulics
Finished the front hydraulic connector mount. I ended up drilling and tapping the loader cross brace for two ¼-20 screws. That’s Rustoleum paint BTW; there is no tractor supply store near by and my MF dealer has convenient store hours that start after I get to work and end before I leave work! My only chance to get to the dealer is on a Saturday.
/ Rear Hydraulics #48
I don't think that I ever did show how I mounted my rear QTs. Here is a picture.
/ Rear Hydraulics
That looks good Jerry! Are those little U-bolts you have on that cross piece to hold your "bejeezus" pins? Why didn't MF weld some on to the lower links of the 3-point where you actually need them on my 1433V?
/ Rear Hydraulics #50
Those are pieces of 5/16 chain. I cut the end off of a link, drill holes in the angle, put the link through and then weld the back. MF did have them on the larger 1200 series. /forums/images/graemlins/mad.gif
/ Rear Hydraulics #51
Need to be careful when installing things on the rear of the tractor. Any welding, drilling or changing of ROPS hardware can void the ROPS certification.
/ Rear Hydraulics #52
Hi. Loulblades, did you ever get a splitter hooked up to tractor remotes? I question the flow rate vs. speed of splitting. My big homemade splitter w/4" cylinder has a 13 gpm pump, and the NH only puts out 9-10. It's too slow as it is! I'm interested if you're having success. And, nice fabrication DMF and others, I also like seeing that.
Jim
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
White Metal Roof Vents (A64194)
White Metal Roof...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
2015 New Holland 560 Round Baler (A63688)
2015 New Holland...
Ford F-450 (A63689)
Ford F-450 (A63689)
