Rear Blade For Loader Bucket
   / Rear Blade For Loader Bucket #11
watch out when using the bucket teeth pointed down in reverse you could damage your loader if you hit a hidden obstruction like a root or rock.
   / Rear Blade For Loader Bucket #12
Having the blade on the rear of the bucket is a much better alternative to tipping your bucket forward when you back drag... it will save the strain on your bucket cylinders. When the blade is engaged, your bucket rams and fully seated inside the barrel. Anther plus is that you've moved the blade several feet closer to the front of the tractor so you have increased down pressure and strength from your loader... This is a patented Westendorf add-on option for all our buckets. LINK
   / Rear Blade For Loader Bucket #13
The rear bucket blade looks like a nice addition. However I have been using the front mounted teeth in a variety of applications for aout 10 years with great success. They are especially useful for picking up tree branches which are almost inpossible with a regular bucket. I suppose they could cause some damage if used improperly, but that goes for all attachments. The extra versitility is worth the care it takes to use them correctly.
How true!!!!!!!
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
TANK MANIFOLD (A58214)
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2020 FREIGHTLINER M2 NON CDL 26FT BOX TRUCK (A59575)
2020 FREIGHTLINER...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
