Rear Blade For Loader Bucket
   / Rear Blade For Loader Bucket #11
watch out when using the bucket teeth pointed down in reverse you could damage your loader if you hit a hidden obstruction like a root or rock.
   / Rear Blade For Loader Bucket #12
Having the blade on the rear of the bucket is a much better alternative to tipping your bucket forward when you back drag... it will save the strain on your bucket cylinders. When the blade is engaged, your bucket rams and fully seated inside the barrel. Anther plus is that you've moved the blade several feet closer to the front of the tractor so you have increased down pressure and strength from your loader... This is a patented Westendorf add-on option for all our buckets. LINK
   / Rear Blade For Loader Bucket #13
The rear bucket blade looks like a nice addition. However I have been using the front mounted teeth in a variety of applications for aout 10 years with great success. They are especially useful for picking up tree branches which are almost inpossible with a regular bucket. I suppose they could cause some damage if used improperly, but that goes for all attachments. The extra versitility is worth the care it takes to use them correctly.
How true!!!!!!!
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
BUYERS PREMIUM & PAYMENT TERMS (A59575)
BUYERS PREMIUM &...
