Bearsixty7
- Joined
- Jun 10, 2015
- Messages
- 1,525
- Location
- St. Paul TX
- Tractor
- LS MT240HE (6/2020). JD LA145. TYM T754C (6/10/25)
I was pouring a slab and figured to have excess concrete so I had the ballast box built and ready. I wanted something that didn't stick back far or wider then the tractor for manuevering in tight spaces.
I calculated the dimensions and was aiming for 1,000 lbs (~50% of what my loader lift capacity is). I got close enough for me
To me the ideal weight of the rear ballast should be 50-70% of your loader lift capacity.
Your tractor will lift a lot with no ballast, so with 50% or more on the 3pt, you can lift all your loader can handle and the rear tires will stay planted.
