REAL Brakes For Your PT-425
   / REAL Brakes For Your PT-425 #31
I checked on tire size just now, but the tires are so covered in dirt, I can't read the numbers. I'll get back to you later.
Bob Rip
   / REAL Brakes For Your PT-425 #32
</font><font color="blue" class="small">( check out burden surplus center, hyd. wheel motors with a internal brake. this would require a new mount.but you could make them. the brake is spring on and hyd. pressure off. no need for a brake pedal /forums/images/graemlins/cool.gif )</font>
Wow. Great website. I wonder if any of these wheel motors would substitute for the PT425s.
What do you guys think?
Sincerely,
Rob /forums/images/graemlins/smile.gif
   / REAL Brakes For Your PT-425 #33
if you have a welder,drill press,cutoff saw and torch you can make any thing work /forums/images/graemlins/cool.gif thats why i think these are the greatest little machines out there /forums/images/graemlins/smirk.gif /forums/images/graemlins/laugh.gif
<font color="green"> Wow. Great website. I wonder if any of these wheel motors would substitute for the PT425s.
What do you guys think? </font>
If you mean interchange with the current motors, the answer is no. I suspect that with enough work and $$$, any motor with a reasonable match to the current motors' hydraulic characteristics could be made to work. However, I see little value in going to that length when bolt on replacements are available.
<font color="blue">f you have a welder,drill press,cutoff saw and torch you can make any thing work </font>
Thanks! /forums/images/graemlins/crazy.gif Now I have no excuse. /forums/images/graemlins/frown.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/laugh.gif
   / REAL Brakes For Your PT-425 #36
My tire size on the 422 is 23 X 10.5 12NHS. These are the bar tires. I would hate to loose ground clearance since I do drive through mud.
Bob Rip
<font color="blue"> the brake is spring on and hyd. pressure off. no need for a brake pedal </font>
Using this kind of motor/brake combo requires dealing with the "how do I release the brakes to roll it when the engine is dead" issue. PT installs something called a BrakeTender on their larger models. I believe it provides a means to pump up pressure manually.
Something like it would be required for the spring/hydraulic brakes.
   / REAL Brakes For Your PT-425 #38
Yes. If you lost the engine or hydraulics, the motor brakes would lock up, then you'd be stuck. There may be some sort of release on the wheel motors, but you'd have to do all of the wheel motors VS just doing the one release on the hydraulic pump on the current setup.
   / REAL Brakes For Your PT-425 #39
what you say is true,but the reason for this is safety. if you lose power,blow a hyd.line, or what ever the brakes go on.you cannot depend on draging the tool you have on the front to stop you going down a hill. a mower deck doesn't lend it's self to being a great brake,or a bucket going backwards.the parking brake isn't getting it,while moving.
you can add a fitting to pump in pressure to move it but that doesn't make sense if it's broke. you fix it then move it out on it's own /forums/images/graemlins/cool.gif
   / REAL Brakes For Your PT-425 #40
MR. if lose hyd.pressure for some reason like a line,leak or what ever.and the brakes come on they just saved your bacon /forums/images/graemlins/smirk.gif you try to run it you will burn up the pumps.now you have more to fix. look at it as a safety factor /forums/images/graemlins/cool.gif thats why all big equip. has that feature built in.after you take a couple rides in an old D9 you will be glad it's there /forums/images/graemlins/cool.gif
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
New/Unused Fuel Pump with 50ft of Hose (A57453)
New/Unused Fuel...
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
20ft Driveway Entrance Gate w/ Tree of Life Design (A57454)
20ft Driveway...
