RE213475 sensor
/ RE213475 sensor #2
Maybe you could embellish your request with more informative info.
/ RE213475 sensor
My Released Position Signal Voltage is 0.6 volts. normal specs are between 0.6-0.9 volts.
My Pressed Position Signal Voltage is 3.9 volts. normal specs are between 2.7-3.5 volts.
/ RE213475 sensor
I am getting errors 01 and 02 while driving. I went into the diagnostic mode and found the voltage on the pedal sensors are out of range. I tried for a while and the best I could get are values mentioned above.
/ RE213475 sensor
I installed a foam stopper to shorten the pedal travel which enabled me to get the sensors within specs.
BOWMAN WEED WICK & MOUNT (A63291)
BOWMAN WEED WICK &...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2016 Chrysler Town and Country Van (A61574)
2016 Chrysler Town...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
