Oct 19, 2015 / RE213475 sensor #1 tervete Member Joined Sep 21, 2013 Messages 27 Location Martintown, ON, Canada Tractor JD 3320 HI, I can't get get the pedal sensors within specs. Does this mean the sensors need replacement?
Oct 19, 2015 / RE213475 sensor #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,691 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) Maybe you could embellish your request with more informative info.
Oct 19, 2015 / RE213475 sensor Thread Starter #3 OP tervete Member Joined Sep 21, 2013 Messages 27 Location Martintown, ON, Canada Tractor JD 3320 My Released Position Signal Voltage is 0.6 volts. normal specs are between 0.6-0.9 volts. My Pressed Position Signal Voltage is 3.9 volts. normal specs are between 2.7-3.5 volts.
Oct 23, 2015 / RE213475 sensor Thread Starter #4 OP tervete Member Joined Sep 21, 2013 Messages 27 Location Martintown, ON, Canada Tractor JD 3320 I am getting errors 01 and 02 while driving. I went into the diagnostic mode and found the voltage on the pedal sensors are out of range. I tried for a while and the best I could get are values mentioned above.
Nov 5, 2015 / RE213475 sensor Thread Starter #5 OP tervete Member Joined Sep 21, 2013 Messages 27 Location Martintown, ON, Canada Tractor JD 3320 I installed a foam stopper to shorten the pedal travel which enabled me to get the sensors within specs.
