Re: PT Skid Steer Adapter
/ Re: PT Skid Steer Adapter #1
ToolcatWonka5610
Mount Morris, Michigan
Ok, So I've been skimming through the PT threads and posts on the Slope Mowers and I came across a Skid Steer Adapter in one of Charlie Iliff's threads. I really like that adapter, I think it would be very useful for us. So I did some research and found that you can possibly use a 90" Bobcat mower on the front of an 1850 or a 72" on an 1845 and other Bobcat attachments. You tell me.
Mower Attachment Specifications - Bobcat Company
The Hyd flow and mower weights are right. I think I may have found a solution to our Finish Mower situation (and I live only a 45min drive from a Bobcat dealer)
You guys tell me what you think.
BTW: Charlie, I think I'll have to steal your WR Long Bucket attachment idea.
(Whoops I'm jumping ahead again with this. We haven't even bought the tractor yet. Sorry I get excited easy by this stuff :D)
/ Re: PT Skid Steer Adapter #2
Lackender Fabrication makes a skidsteer adapter for a PT, unless I'm mistaken..
Be aware that if using hydraulic-powered implements, then the Power Trac's PTO doesn't typically put out the flow or PSI that a skidsteer does. Be careful and compare specs..
Ok I'll look into it.
Well I jst checked some of the specs on Bobcat loaders. The Larger Framed machines have 3300 psi hydraulics. But the Toolcat has an 18 GPM flow @ 3000 psi, which is actually the machine a Mower is ment for. Close psi but still wrong (1850 has 18 GPM @ 3,200 psi).
Could it be done?
/ Re: PT Skid Steer Adapter #5
I would think it is fine - worse care put in a 3000 psi bypass but i find it hard to believe 200 psi makes a difference.
Ken
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2022 WACKER NEUSON EZ26 EXCAVATOR (A60429)
2022 WACKER NEUSON...
