Raytgal
/ Raytgal #1
raytgal
I recently obtained a Kubota that I was told was a B1600. I am trying to get all information I can about it. The dealer gave me a I&T K-201 shop manual and said I should use the info on the B6100D as this is the closest US crossover. Does anyone know for sure? I would like to obtain a parts manual. The problem I'm having a this time is - Just a couple weeks ago I had to replace one of the rocker arms that had snapped off. It was running fine for a little while and then started running bad again. This time I found that the rocker shaft had broken on the back end (by the last rocker). I had adjusted all the valves and it appears to be getting a lot of oil up there.
Any suggestions?
/ Raytgal #2
I can try to get you a parts book from Japan.
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
3148 (A63117)
3148 (A63117)
2019 LAYMOR SM300 RIDE-ON SWEEPER (A65053)
2019 LAYMOR SM300...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2005 Kubota L39 (A64126)
2005 Kubota L39...
