Raul5452
/ Raul5452 #1
Raul5452
Corpus Christi Texas
John Deere 970, Kubota M7060
Toe in on a M7060. Purchased on 2017. I'm getting some playing in steering on street driving in high range. I'm at 2000 hours. Manual recommends toe in adjustment. Do I just turn front wheels as straight forward as I can visually ? Then what points do I use for accurate measurements ? Do I adjust both sides tie rods ? Appreciate any help.
/ Raul5452 #2
Your OP manual also tells you HOW to make any adjustments. When I check the toe-in/toe-out, it takes two people. Measure across the tractor. Distance across from front of front rims vs distance across from rear of front rims.
/ Raul5452
Thank you Oosik, I referred to op manual gives me tolarance, tells me to measure center of tire to center of tire. But it seems to me that I shouldn't just take out the difference from one side only or am I wrong ? I've be wrong many times before. lol. Manual does not give details how much to adjust on each side. Just a .008" to whatever. I don't remember the other dimension.
/ Raul5452 #4
You must toe each side equally. I suspect your tie rods are shot instead, If they rotate (end) easily, time to replace.
/ Raul5452
Thank you 5030, really appreciate the info. Tie rods are good and solid. I will give it a go.
/ Raul5452 #6
No matter how it plays, always make sure the inner joint boots are intact and grease tight. The inner joint, because it's a radial joint is about 5 times as expensive as the tie rod ends and is only a dealer item.
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
NEW Wolverine 78" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 78"...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Quick Attach Grapple Bucket (A66285)
Quick Attach...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A65579)
INOP/NON - RUNNING...
