Rat Disaster. Need Electrical Help.
/ Rat Disaster. Need Electrical Help. #41
A small butane fired pencil soldering tool has served me well on many such repairs.
Also, something I tried recently, and it works great. I had a wiring harness on an ATV that was originally mounted too close to the exhaust, and it melted/rubbed the harness so about 1/2 dozen of the wires in the harness were rubbed clean thru to the copper.....didn't break them, but did short out to the frame.
I pulled them apart enough to where I could spray them well with Plastic Dip rubber/plastic spray (Lowe's store). Did a light coat, let it dry, hit with a couple more coats, and then taped them all back into a bundle and hit it again. Worked great !
/ Rat Disaster. Need Electrical Help. #42
Usually the wire makes the decision for me when it comes to soldering. Often times copper wire will tarnish as it ages and gets exposed to the elements (even under the insulation). When you strip the wire it'll either be a nice bright copper, in which case you can solder it, or it'll be a dark brownish color and solder isn't going to make a good connection. I like butt splices but I also have an expensive Amp crimping tool designed for them. If you do a number of splices and other terminals I would do a search (Amp 59824) on ebay and pick one up. I've seen them as cheap as $50.
/ Rat Disaster. Need Electrical Help. #43
I have never worked on a Kubota but i'm thinking that if you have a look behind the rubber on the dash panel there will be a connector in there. Being able to remove the dash panel will give you more room to work.
I was thinking along the same lines. If an option under consideration is replacing the harness, then you'd have to remove and reinstall the harness. So remove it, and then make the decision whether it's worth the price of a new one to fix the existing one.
If I can get the wires off of the back of the dash unit without destroying the rubber seal I will try soldering. As mentioned I have all the stuff except the heat shrink which isn't expensive. If I cannot get it of the back of the dash unit I will butt splice with heat shrink. Unfortunately I do not have the dash unit here at home. Would anyone hazard a guess, based on the pictures I posted or past experience, what size these wires are?
/ Rat Disaster. Need Electrical Help. #45
They should be the instrument cluster and indicator light wires...On my B series there is a modular plug (part of the harness) that completely disconnects from the dash/instrument panel...
Just curious...How would you install a new harness if you went that route?
Me? I'm not sure I understand your question. To replace the entire harness you'd just remove the old one and put the new one in its place. I'm assuming it comes with all the proper connectors installed at the ends. It would take a lot of careful planning and attention to how the old one was laid out to determine how to route it.
/ Rat Disaster. Need Electrical Help. #47
Eh, I'm looking on a monitor that is not very clear. But I might venture to guess 18 gauge? It looks like there may be some that are a different size? It almost looks like even 3 sizes? Thats how fuzzy the picture is on my monitor. Either way, I think 18 gauge should be sufficient for gauges. If any look thicker than the rest, bump those up to 16
/ Rat Disaster. Need Electrical Help. #48
On the topic of the harness assembly. I don't know about tractors. On vehicles, many models are made in sections for replacement purposes. Engine harness, dash harness, chassis harness, etc. Unplug the bulkhead connectors and all related component connectors and clips holding it in place and remove the harness. Easier said than done, its usually snaked through all the other plumbing, it doesn't just lay on top of everything.
I kinda doubt tractors would be made this way since there is much less involved. Not near as many plugs, and a much shorter length to cover. Its possibly one harness to cover the entire tractor. Or maybe just one or two whereas a full size pickup may have a half dozen or more. You would have to research your particular model, you might be getting yourself into quite a hot mess...
Edit: I said the harnesses are made in sections for replacement purposes. That is undoubtedly incorrect. NOTHING on a vehicle is made to be easily replaceable. I'm sure its made that way for quick assembly. Easier replacement is just a nice side effect
/ Rat Disaster. Need Electrical Help. #49
looking at the pictures...I suspect that behind the rubber moisture boot there is a modular plug that connects all the wires to the panel... thus my question about a new harness...
/ Rat Disaster. Need Electrical Help. #50
..... If brass wool is known to keep the mice out I may stuff that space with it. There is nothing in there it would interfere with......
I would avoid filling that cavity with brass wool given the presence of wires, electricity, potentially broken wires shorting, etc, due to flammible nature, see cautions here Lustersheen Brass Wool.
Thx
/ Rat Disaster. Need Electrical Help. #51
I had the same problem with a BRAND NEW car. Had to pay to have it towed back to the dealer and $895 for new wiring harness. And the insurance would not cover the cost. That was over twenty years ago - check to see if your insurance will cover this cost now.
My solution - one entire box of moth balls spread under each vehicle and MANY barn cats. No problems since.
/ Rat Disaster. Need Electrical Help. #52
George look on the Kubota website, it looks like there are several connectors, dash panel, key, combinition(lamps) switch etc.
there are wiring diagrams you can look at and part lists.
Kubota Tractor Corporation - Parts List
/ Rat Disaster. Need Electrical Help. #53
Do you happen to have kubota insurance. Not sure if this would be covered but worth a call.
No insurance.
I have the factory service and parts manuals, so I have the wiring diagram and a picture of the main harness. It looks like the main harness is one big ol' octopus.
I was wondering about the brass wool shorting something out under there but did not think about a fire hazard. I'd still say chances would be pretty low.
Scott, all the wires are the same size. 18 seems right.
/ Rat Disaster. Need Electrical Help. #56
George, Just because you do not have specific tractor insurance does not, necessarily, mean you tractor is not covered. My tractor is covered under my homeowners policy.
/ Rat Disaster. Need Electrical Help. #57
I work on electronics as a hobby. I could have those wired back together in no time. The trick is you just need a $4 harbor freight soldering iron, one of those red handled $5 wire strippers, some good 63/47 solder from radio shack and most importantly good flux. You want the rosin stuff, not the acid flux. Easiest way to tell you how to do it is to make sure your tip is clean, and as the iron is heating up wet the tip with the tip with the solder until you get a nice blob going on then let that heat up. Slip some heat shrink wrap tubing as far back away from where the two wires will join, apply liberal flux and just touch the blob to the wires. In a couple seconds it will flow onto them, let cool, slip the heat shrink tubing round the joined wires and take a lighter to it to shrink the tubing.
/ Rat Disaster. Need Electrical Help. #58
It could be wired back up in less time than reading this thread. Very good thread, but it seriously is not that difficult.
/ Rat Disaster. Need Electrical Help. #59
On the same note...it is not a skill with a difficult learning curve...with a modicum of eye-hand coordination the average klutz (m/f) can become quite adequate in a very short time...IMO a very useful skill every DYI'er should possess...
/ Rat Disaster. Need Electrical Help. #60
I agree 100% with this. I can solder. Quite well in fact. I do it every day as part of earning a living, it's hard to imagine not being able to. I don't mean this in a rude way to those that can't. I mean once you know how, you realize there are a lot of tasks that are performed better with this knowledge. Let's not forget plumbing. Different heat source, same principle.
BUT, I do remember a time when I couldn't say this. I remember watching someone and they made it look so easy. But I, myself, didn't understand the workings behind it so when I tried I failed. Again and again. It's very frustrating. Especially when your trying to do it under the good of a car. Or, let's say, the dash of a tractor. Like many have suggested, practice on some spare wire, out on a solid surface. Watch some YouTube videos. It really isn't hard once you learn the "tricks". I really don't mean it to brag, only for perspective. For me, doing it every day, that bundle of wires would be about 15 minutes to solder, shrink, tape, and re loom
I don't think words could describe well enough how to do it. YouTube probably has lots of videos where you can see where to apply the heat and how it should flow. Grab one of these to hold your wires while you solder them, it's how i avoid twisting them as mentioned before:
It's an LI55000 from Lisle Tools but I'm sure other companies make them, maybe harbor freight.
The one thing I will say about how I do it that seems to be some different. Rather than twisting or bending, creating fat spots or weak spots to break later. I strip a quarter inch from each wire. Slide on about a 3/4" piece of heat shrink. Dip one of the wires in flux. I straighten the natural twist of the strands of wire so they will "mesh" together. It's kind of a trick to get them to stay just right, hence the tool pictured. Don't leave strands poking out, it's a short waiting to happen. If needed, twist a little after they are meshed together to get them to lay flat. Now apply heat to flow the flux, followed by solder.
Doing it this way with the magnetic tool and my thermostatic solder station to maintain the temp, I pre strip all the wires and each joint takes just a few seconds. The result is a soldered joint stronger than, and nearly as thick as the original insulated wire. The only added thickness is the heat shrink. My customers never can tell where I was
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
TRIP HOPPER JR CUBE / CAKE FEEDER (A64278)
TRIP HOPPER JR...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
