Randy
   / Randy
its a mahindra 4550 4wd not4540
   / Randy
   / Randy #13
No worries. It is an interesting project and I look forward to see how it works. Just be mindful of the forces involved to protect the loader.
   / Randy
I'll try to get one. The backhoe works as long as someone is on tractor pushing third function
   / Randy #17
That would be correct. I would not do that long though as the coil on the third function’s life will be shortened.
   / Randy
could you tell me what ports from diagram to hook up to hoe,sorry to bother you,I no nothing,dealers arround hear says it want work.
   / Randy #19
I sure will. I still would like to verify the backhoe valve as to not mislead you. The dealer is probably concerned about the loader being able to support the stress like we are. However, depending on what your plans are with the backhoe and take it easy you probably would not have issues.
Once you can post pictures of backhoe valve and a diagram I will draw the lines for you.
   / Randy
thank you very much ,iwill go take some pic, an get back in touch,Thanks
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
SHOP BUILT 96" X 25' TRI AXLE GOOSENECK TRAILER (A51247)
SHOP BUILT 96" X...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
BOBCAT T595 LOT IDENTIFIER 140 (A53084)
BOBCAT T595 LOT...
