Randy
   / Randy
its a mahindra 4550 4wd not4540
   / Randy
   / Randy #13
No worries. It is an interesting project and I look forward to see how it works. Just be mindful of the forces involved to protect the loader.
   / Randy
I'll try to get one. The backhoe works as long as someone is on tractor pushing third function
   / Randy #17
That would be correct. I would not do that long though as the coil on the third function’s life will be shortened.
   / Randy
could you tell me what ports from diagram to hook up to hoe,sorry to bother you,I no nothing,dealers arround hear says it want work.
   / Randy #19
I sure will. I still would like to verify the backhoe valve as to not mislead you. The dealer is probably concerned about the loader being able to support the stress like we are. However, depending on what your plans are with the backhoe and take it easy you probably would not have issues.
Once you can post pictures of backhoe valve and a diagram I will draw the lines for you.
   / Randy
thank you very much ,iwill go take some pic, an get back in touch,Thanks
UNUSED CFG INDUSTRIAL XZ20R EXCAVATOR (A51247)
UNUSED CFG...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2011 BOMAG BW211 D-40 SMOOTH DRUM ROLLER (A51246)
2011 BOMAG BW211...
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
