Ramp/Bridge
/ Ramp/Bridge #11
</font><font color="blue" class="small">( I'm looking for a lightweight (aluminum?) ramp to use as a bridge to get across a little stream on my property. )</font>
what size stream? how wide and how deep.
/ Ramp/Bridge #12
</font><font color="blue" class="small">( Yet another idea might be to place a short section of culvert in one or two inconspicous locations covered with dirt/gravel even if you had to drop down and climb back up a bit.
One could also perhaps construct a "ford" with rocks and/or concrete to cross the stream in one or more places.)</font>
Depending on where you live, either solution might require a permit from the state agency that regulates waterways, and possibly from FEMA. Adding a culvert or a ford changes the channel conveyance and can increase the back up of water in a flood. You may not be allowed to back up additional water off your property, and may be required to prove that you are not backing up additional water.
If you build a culvert, leave the roadway low so a flood that overtops your culvert will kinda stay in the channel and won't make too much of a mess.
A bridge would have the same requirement as a culvert or ford, but a portable bridge might not, particularly if it lives in your barn.
A call to the State Dept of Tranportation or Office of Water Resources, (It varies from state to state) or your County Engineer should tell you if and what kind of permit is needed.
The engineering required for a stream crossing permit is not trivial. Neither is having the Corpse of Engineers show up with cameras and clipboards.
/ Ramp/Bridge #13
Sorry I posted the home page and not the dirrect link to the larger bridges.
as for weight We have not done any full on stress testing but they should be able to handle the typical sub compact tractor weight. we drive the golf cart over them as well as small rider mowers. for larger tractors we would have to beef up the bridge to hold the weight.
this is the link to the bigger bridges http://www.bright.net/~pfryman/forsale/ what we are planning on selling retail is the smaller bridges for walking over the streams and using rider mowers to get over them, if you plan on pullind trailers loaded with logs or big rocks and have a 3~4K tractor then those design weight has to come into play.
anyhow you can give the boss a call most anytime for a price for a bridge. you would need to have the SPAN and how much arch if any and keep in mind that if you have a ditch that is 10' across from crown to crown you need to keep at least 2 foot of stable ground between the bridge footings and the stream/banks' side. anyhow phone numbers are there too but under the info page here http://www.bright.net/~pfryman/info/
http://www.bright.net/~pfryman/forsale/12020003.JPG
Mark M /forums/images/graemlins/grin.gif
/ Ramp/Bridge #14
Man, I hate those sites that stick 'lebenty seven pictures on one page. By the time it's loaded I've forgotten what I wanted to see. I could almost understand if the items were related in some way, but what's the point of putting the bridges on the same page as all those ovens? /forums/images/graemlins/mad.gif
/ Ramp/Bridge #16
</font><font color="blue" class="small">( Man, I hate those sites that stick 'lebenty seven pictures on one page.)</font>
Yeah, it's not a very well designed website.
/ Ramp/Bridge
</font><font color="blue" class="small">( Yeah, it's not a very well designed website.)</font>
True enough, but to my untrained eye it looks to be some fine metal work.
Jim
/ Ramp/Bridge #18
Sorry guys: I'm a metal former and electrical farmer! hahah I am the one who put all those pictures on there. true I'm not much for web design! I'll hand you that one roflmao. also most buisnesses have DSL or high speed internet connections, not that many of us cuntry folk have that type of thing... I at one time had cable and the page even with all those photos loaded in about 2~3 seconds... yep dial up that's 2~3 min. I've been trying to limits the photos but when you try to explane what we do it is easier to say here is some pictures.
I've been putting SMALL photos with link to larger full size by clicking but it's spring and time on the tractor is more importaint! /forums/images/graemlins/tongue.gif
Mark M /forums/images/graemlins/cool.gif
/ Ramp/Bridge #19
Spiker, seems to me like you have your priorities just right. enjoy your tractor and your metal.
Mike
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
Trailmobile Van Trailer (A61307)
Trailmobile Van...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
13042tx (A55973)
13042tx (A55973)
