ram 6.4 hemi
/ ram 6.4 hemi #41
"Several companies are producing engines that meet EPA standards without urea systems, already, and it's only a matter of time before they all do."
I don't believe this is accurate. The reason that 'others do' was for lower mileage engines that didn't need the fuel efficieny. It is well known you don't need SCR if you don't create the NOx. The way you don't create the NOx without an SCR is by severely retarding the fuel injection timing & adding EGR. Then your fuel mileage goes way, way down. Ask Navistar how that worked out for them (now buying Cummins engines). Heck, CAT got out of the on highway truck business for that reason.
And finally, Cummins first ISB6.7 (Ram) engine recipe had no SCR - but the fuel consumption was so high & they got so many complaints they changed to SCR a few years back just to get the mileage up.
Reducing NOx is not that simple. Gasoline spark ignited engines don't make nearly the NOx that diesels do - because they aren't as efficient, they don't burn as hot.
/ ram 6.4 hemi #42
When they combine Direct Injection and Direct Ethanol Injection with a high compression turbo motor, I think that will be the end of the light diesel. I am quite surprised that no one has implemented that yet.
I think we're already there, with DI gasoline, VVT, & ACM. What's the point of a diesel unless you need the low end torque (and higher fuel mileage) for nonstop towing? The grocery-getter crowd won't be able to afford light duty emissionized diesels.
That's why it is interesting to see that happens with these just coming out. I think they're 10 years too late to market.
/ ram 6.4 hemi #43
With the Ethanol injection you can drive the cylinder pressure to diesel levels without pre-ignition or detonation. They will have torque curves just like a diesel, that will not taper off.
Ford Bobcat
/ ram 6.4 hemi #44
Ford Bobcat
Not without building diesel cylinder pressure capable cylinder heads, engine blocks, pistons, connecting rods, crankshafts, torsional vibration dampers, and transmissions.
So the point would be............???
/ ram 6.4 hemi
In the short run, maybe, Ford took a terrible beating from them (aka 6.0), but honestly Dodge and GM just kept humming, I think. They are coming back stronger, with mileage coming close to before emissions, and I have to admit, cleaner than before. I know some like the "smoke" but personally that kept me from diesels more than anything was the smoke and smell.
Gas engine went through the exact same process in the 70-80's, and are coming around stronger and faster than before and getting better mileage to boot.
Diesels will only get better. Several companies are producing engines that meet EPA standards without urea systems, already, and it's only a matter of time before they all do. If the EPA will back off it's goal of eliminating diesels from the market, the free market engineers will make gas engines a thing of the past. All one has to do is look at the numbers. If I am not mistaken, there is some 40 cars available in the 2014 market, in the US with diesel options. Reaching peak torque at half the RPM, equals better pulling (for passengers and loads) and higher MPG.
The way I feel right now, when the 2005 Honda we are driving meets its time to go, it will be replaced with a diesel. When a majority of the market wants diesel, then prices will fall in line. To me, it's the same as when unleaded gas came along, except this time it will be consumers demanding it instead of the government. From what I have read, diesels actually have the potential to be cleaner than gas engines, PLUS diesel fuel is safer to transport and store, due to the fact that is does not ignite as easily as gasoline.
It took me quite a while to convert my thinking, but now that I have, I see them as the future, in internal combustion. No longer are diesels the slow, smelly, lumbering engines going up hills at half the speeds of everyone else. It's like comparing a Shetland pony to a Clydesdale (that easts like a Shetland). Both are 1 horse power, but one can do a LOT more work.
I dissagree, the EPA is not going to back down on diesel emissions. They now require urea on tractors. I do agree on the new diesels being less stinky. I loved that about my dmax, but the dpf systems cause more issues then there worth. If I had a nickle for every time I said I'll never go back to a gasser, I could have substantially lowered this truck payment. Good luck with your diesel, I truly hope you dont have the issues I've had, and you get many trouble free miles out of it.
/ ram 6.4 hemi #46
1100 HP gas motors are fairly common these days using factory short blocks. even Ford shortblocks..... :D
/ ram 6.4 hemi #47
Yea, that's on the low end for dem Ferds. Had to give the Bow Tie crowd a fighting chance so they backem off a bit!
Chris
/ ram 6.4 hemi #48
at what rpm? practical for towing from a stop light? pop the clutch @ 10,000 rpm?
/ ram 6.4 hemi #49
well no. I was pointing out that gas motors are very tolerant of boost pressure with the advent of fuel injection and digital ignition timing. The ecoboost proves this out. The guys that push 1000 HP and beyond have a turbo the size of a garbage can lid and achieve those numbers well under 7 grand.
Now add ethanol injection to the mix and high compression pistons and you have the potential for some really stout, but small powerplants. You would have a separate ethanol tank much like a DEF tank.
/ ram 6.4 hemi #50
2500 w/6.4L ordered and now in production. Let the wait continue 6-12 weeks.
/ ram 6.4 hemi #52
Mazda is producing one (not here yet) and so is Honda, also not here yet. There is one other but name brand escapes me for the moment. As for Dodge, their mileage sucked because they were using a 7th injector in the exhaust to overheat the exhaust to burn off the soot in the DPF. To me it's a matter of the engine makers "learning" how to do it right. Go back to the 70-80's and look at the engines that were produced that "met emission standards" of the day. Good Lord. A 460 cu in engine that produced under 300hp, and got about 7 mpg, but boy was that "clean". As posted earlier, the people need to get control of the EPA, they are controlled by world interests that have NOTHING to do with cleaning the air. They want to force combustion engines out of the system, whether diesel or gas. Look at the "new" standards they are creating for the next 10 years. It's mind boggling.
Back to the 70's, the engines produced pathetic power because they often lowered compression to about 7 to 1 in order to "clean" them up. Of course the fast that they used twice as much gas to do the same work was of no consideration. We need to look at emissions per mile, instead of emissions per gallon as we currently do.
Just as Ford figured out that opening the exhaust valve much earlier in the lower RPM range to "pre-boost" the turbo in order to get the low end torque the Eco Boost is famous for, I predict diesel engine builders will do similar things to make the exhaust hot enough to make it "clean" so the greenies can't sniff it. The people in this country are really starting to make me very scared. It's not OK for a little diesel smoke (or CO2) to come out a tail pipe but boy lets stuff as much weed into our brains as we can, LEGALLY, no damage done there.
I do not believe the diesel is going away, in fact, as I said, it will only get better. Heck Mercedes has been at it for many years, now Honda, Mazda, and BMW are getting into it. Race cars are embracing the diesel engine as well. Not just the truck drags, but SCCA cars as well. There's no way these guys will invest millions on dying engine technology.
Some of them are producing 400+ hp from 2.0L engines with 600+ torque. To put it to the ground all that's needed is gearing. Plus that low end torque is a dream come true for coming out of the corners. Sure you can gear a gasser down to keep the revs up but that's more shifting, more gears needed to keep them in the curve. Of course diesels do suffer from the opposite end of torque drop off at higher RPM, but not as much in race applications where engines regularly hit 5-6K rpm.
/ ram 6.4 hemi #53
Anyway, I'll shut up about diesel, and let the OP enjoy his new truck. As I mentioned, I'm glad the auto makers (or at least Dodge) has finally put the grunt where it need to be. One guy we RV with has a Ford F250 with the 6.0 (I think) and 6spd auto, and he loves it for a lot of the reasons you guys cite here in a gas vs diesel debate. As he said he pulls hills slower, but makes up for it on the flats. His words not mine.
/ ram 6.4 hemi #55
I am not sure why the pictures above don't load correctly. Since we all like pics, here are a few more in better lighting.
/ ram 6.4 hemi #59
Thanks! I wanted the extra interior space...so I went with the Mega Cab.
/ ram 6.4 hemi #60
The megas have some incredible cab space for sure, no other truck out there can match it.
Bobcat Severe Duty Forks and Frame Skid Steer Attachment (A64553)
Bobcat Severe Duty...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
HARDEE 16' T/A TILT BED TRAILER (A64278)
HARDEE 16' T/A...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
