rake/driveway question
/ rake/driveway question #1
bellweather
Platinum Member
Western MA
Kubota BX22
I took advantage of the damp weather and raked my gravel driveway. I was successful in eliminating pot holes and ruts, however I created other problems:
washboard effect - seems that once these occur, it's difficult to avoid componding the problem because everytime the tractor climbs up and down a mound, the rake will dig in deeper as the tractor is going up and then make light contact on the down side.
windrow - as I raked, material escaped the rake and was deposited at the edge of the driveway. This created a kind of a raised border or dam along the leangth of the driveway, which had the effect of containing the rain water. I had to resort to using a hand rake to disperse this ridge of material. I tried changing the tilt and angle of the rake, but with only moderate improvement.
I'm assuming it's the operator and not the equipment, so any tips would be much appreciated.
Thanks
/ rake/driveway question #2
Bellweather,
You need the gauge wheels on the rake to get rid of the washboard effect. This way you let the rake float and the tractor going up or down will not have an effect on it. The wheels make all the difference in the world. Will help with the windrowing as well.
/ rake/driveway question #3
Bellweather
Do you have gauge wheels on your rake? Carefully using them with the proper angle of attack on the rake will get rid of the washboard.
To get rid of the windrows, I angle my blade to deposit the windrow in the center of the road. This redirects your gravel back onto the surface where it is needed- off the edge and and any shoulder. I do this up each side. I then raise the rake, returning it to a "straight" position and distribute the combined windrow in the center. Because the rake is raised, much of your material will slid along the rake and dump out before it reaches the edge. I hope the above is clear. It took a little fiddling and sometimes I have to make more than one pass.
I think you will find that rake the best thing around for road maintainence. /forums/images/graemlins/grin.gif
Rick
/ rake/driveway question #4
bellweather:
I've used my rake and box blade to maintain my driveway and the gravel roads in our subdivision for the last several years and here's what I've found:
You can't repair potholes, ruts and washboard with the rake alone. After raking, it may look like you've eliminated the potholes but all you've done is fill them in with loose gravel. I've found that I need to run the boxblade with rippers down up and down the road several times. The box/rippers should be set so that the rippers are just deep enough to get to the bottom of the potholes/ruts/washboard. Set the top link of the box so that the blade itself isan inch or so above the surface of the road. When you start ripping, the box will get a nice roll of gravel in it and start to help eliminate the washboard.
When you're done with the box, put on the rake and set it at an angle (i.e. rotated) and also swung around so it's "Back raking" run the rake starting at the outside of the road so that the windrow deposits toward the middle - this will help set the crown.
Once the angled passes are done, set the rake straight, but still in the "back raking" direction and starting in the middle, make a finish pass.
By "back raking" do you mean with the tines actually pointing opposite the direction I'm traveling, as in rotating the rake 180 degrees? Thanks
Thanks for the reply. I had a feeling gauge wheels might make a difference. I don't have them now, but maybe I should get some. Also thanks Von for the same advice.
/ rake/driveway question #7
I would say yes, I do this with my rear blade for fine smoothing. The blade can't dig in when its turned around it just glides along the top for the most part.
On my drive I've had the best luck using the box blade. I don't get washboards thier more like moguls or big spaced out washbords. Its almost like a mini roller coaster, kinda hard to describe. It happens most from equipment trucks spinning thier tires slightly up the 500'+ semi steep drive. The trick on mine is to cut the top off the first mound to get some material in the box. Then another hieght adjustment on the first dip this gets me on a middle point more/less for the first pass. Depending on how much material is in the box I may adjust up or down very slightly once or twice. You dont want the box empty, I try for about 1/8 to 1/4 full. After a couple passes each way its smoothed out.
Once thats done then the blade works good to move rock one direction or the other. If it windrows flip the blade backwards drop it an go, it takes care of itself. I would assume the rake would do the same thing.
/ rake/driveway question #8
Some of the regulars have already seen this. It's a couple of steel beams fastened together with 6 pieces of 1/2" allthread. By lengthening/shortening the two lower chains, it will cast the loosened material to the right, left or straight.
My first tractor didn't have a 3PH, and it was pretty unhandy not being able to pick it up. With the boom pole, it is 100% nicer to use. Since our main driveway has been paved, it hasn't seen a lot of use. About the most it gets used anymore is to flatten out the sand volleyball court................chim
/ rake/driveway question #9
Yes, that's what I mean by "backraking". I found that with the rake facing the normal direction it was too "aggressive" and wanted to move the gravel rather than smoothing/spreading it.
I don't have guage wheels for my rake but I wish I did. They would be a big help in reducing the "whoopty bumps".
Thanks WVBill and CTyler...I like your term "whoopty bumps" that about describes the washboard effect I was referring to...not really a washboard but more like regularly spaced mounds. I will try back raking/back blading.
/ rake/driveway question #11
I use a york rake on my crush driveway. Before I got my tractor I used the rake on the back of my Astro Van, took of the 3PH from the rake and put a trailer hitch on it, it worked great. With the tractor I dig deeper, probably because of the hydraulics pushing it down. I think I need the gage wheels. It still does a great job but I do experience the moguls. The worst is when you get a bucket of crush, and fail to dumpi it in just one pile. Then the tractor hits the first pile and the raises the rake when it gets to the second pile. Either dump it alll at once or space it out beyond the wheel base of your tractor.
LOL, Frank
/ rake/driveway question #12
Angling the blade wil not only help with the windrow effect but also the bumps. Angling helps the rake to dig in better and also spreads out the bumps over more distance. I've never used the rake backwards - probably because with gage wheels the're not a digging in problem.
/ rake/driveway question #13
This is a timely thread. I've got a 700' gravel driveway to maintain. Half of it is level and needs very little maintenance. The other half is on a slope (not steep) leading up to our garage, house, and barn. The gravel (recycled asphalt) gets washed down the slope by heavy rains, leaving a pile of gravel at the bottom, deep ruts along the sides, and a variety of ruts, potholes, and bumps scattered along the rest of the driveway. I've got a TC33, and need to apply the right implement and technique. I already have a rear blade, but using it alone can do more harm than good. Would a LandPride LR 05 or LR 15 series rake )w/gauge wheels and the flip down blade) do the job? I'd also like to read more about people's techniques for doing this.
TIA, Peter
/ rake/driveway question #14
</font><font color="blue" class="small">( I already have a rear blade, but using it alone can do more harm than good. )</font>
Why is that?
You can angle the blade back/forward for more/less bite. If you turn the blade around backward it will smooth only. Angle it to put material where you want it.
Other peeps have talked about using gauge wheels to help keep a constant depth. I use a box blade and/or rear blade for mine and its about 600' or so and mostly hill.
/ rake/driveway question #15
Gosh, I didn't think of turning the thing around...I'm still kind of new at this [can't you tell? ;-) ]. But does a rear blade really do as good a job as a rake and/or box blade? You said that you use both a rear and a box blade? Not that I'm dying to buy another attachment..unless it's a better tool for the job.
-Peter
/ rake/driveway question #16
Just curious, I have almost every attachment for my tractor but have never heard of a york rake. Could someone send me a picture of one. From what I read on this forum they seem to work real good for those of you who owns one.
Thank you.
/ rake/driveway question #17
I've got a 300' slope that will get 10" gullies when it rains hard. With the york rake the best I've found is to use it with no angle whatsoever. With the angle I tend to dig unevenly and have piles. I have also found that if I limit how far down I allow the 3PH to drop the rake by adjusting the upper arm I don't dig so much. I do wish I had gauge wheels, but I see myself making some soon, since I saw one post where someone paid $250 for a pair.
My hill will get washed to the bottom also with the crush, but it holds up pretty good. The best solution I have found to get the water off is to put "speed bumps" up on an angle to divert the flow. Usually one every 100' seems to do the trick. This will save you ooodles of time and material.
LOL, Frank D
/ rake/driveway question #18
Here's a pic of a Landpride unit...not a recommendation, just the easiest pic to grab !!!!
York is a manufacturer's name. It has become the 'slang' name for this type of rake, although a bunch of folks make them.
/ rake/driveway question #19
Hi,
I use the box blade to smooth out the dips in the drive. The BB better at gathering material, cutting high spots and filling low spots. The lumber, cement, steel, dump, etc.. trucks are doing wonders for my drive. When going back up they just barely spin the tires once in while. Its hardly noticable when it happens but it starts creating "woopty doos".
The rear blade is better at moving material side to side and smoothing. If I would swipe the drive with the rear blade a couple times a week it would work ok. Instead I wait a couple weeks until its trashed because I'm buried doing other things during construction.
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2018 Case TV380 (A64126)
2018 Case TV380...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
