RainX on plexiglass
/ RainX on plexiglass #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
Has any one used RainX on the plexiglass windows of their homade cabs. The bottle said to test on acrilics before using. I tried it on a scrap piece and didn't see any harmfull effects. When I rinsed it off with water I couldn't tell where I had aplied the RainX. Does it work differently on acrilics that glass. I use it on all my vehicles with great results. I made a front winshield for my F2100 to keep some of the snow off of me while snow blowing (if it ever snows here). I was going to try the RainX before installing a winshield wiper set up.
Bill
/ RainX on plexiglass #2
Bill
I ruined a Harley windshield with it, got cloudy.
/ RainX on plexiglass #3
I personnally wouldn't use it on plexi. I'm not saying it won't work, but to me, it's not worth the chance of ruining the windshield. I've had good luck using automotive wax on plexi and had good results. It may not be as good as RainX on glass, but it does a pretty good job.
The reason it destroyed the Harley windshield is because there is a plastic laminating sheet covering on the windshield that helps to prevent the windshield from shattering when struck - that's what went cloudy. I also use auto wax on my Harley windshield without any problems.
/ RainX on plexiglass #4
Someone on TBN recommended Meguiar's brand. I used it on the windows on my soft cab and was impressed. It removed the cloudiness and seems to work like the rain-x for shedding water.
/ RainX on plexiglass #5
Used rainx on the plastic windshield of my RTV....Didn't seem to hurt anything but couldn't see that it helped either. I do use it on my vehicle windshields.
/ RainX on plexiglass #6
I use Meguiars Scratch X 2.0 on any clear plastic, removes minor scratches and leaves a water shedding polish. The most impressive use is on my reading glasses, they stay clean and clear much longer using it. I even use it on real glass.
/ RainX on plexiglass #7
You dont want to put anything on plexiglass with alcohol or especially ammonia(Windex or other glass cleaners) as it will cloud the windshield. I used to use a special aircraft windshield polish on the window of my Cessna that cleaned and polished. Cant remember the name now. Diamond Pilot might have some input on this.
/ RainX on plexiglass #8
Meguiars Mirror Glaze product line is favored by the aviation industry. Worked at a Piper parts distributor for a few years, that is what we sold. Scratch X is a fine polish, easier to find at almost any auto parts store.
I have the Meguiares cleaner and polish.I use it for cleaning scrached acrylic just didn't think of using it on a new windshield. Woud you just use the polish and not the cleaner.
Bill
/ RainX on plexiglass #10
Bill
That's exactly the brand I use. I first use the cleaner/polish, then a coat of wax does the trick...for me! As always, YMMV, JMHO!
/ RainX on plexiglass #11
On plexiglass, RainX will make it cloudy and your wipers you are planning will make it streaked. Lexan on the other hand is harder, shouldnt turn cloudy and wont streak as easy under the wiper blades. Also, plexiglass will turn brittle out in the sun in a very short time and turn cloudy just from the UV rays. It also cracks very easily. If you are going to make a windsheld, use Lexan instead of the plexiglass. All of our equipment has either glass or Lexan in it and we use rainx all the time because it helps keep the dust from accumilating on the windshield. We have also tried plexiglass in order to save a little money, but it was only a few weeks before we had to change it out due to scratches and getting cloudy.
/ RainX on plexiglass #12
I have used lemon pledge on plexi for years , both on gliders and aircraft works great
/ RainX on plexiglass #13
Are you talking about Novus #1 ?
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
Peterson Horizontal Grinder (A62613)
Peterson...
213097 (A64276)
213097 (A64276)
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
