the old grind
Elite Member
- Joined
- Jul 21, 2012
- Messages
- 4,405
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
(Followers, notice at 14:00 in the long video how side-boom cranes have a c'wt that extends out according to load.)
Near the end of the short video you can see wind blowing snow in front of the camera. It appears the center-beam cars caught more wind than their empty weight could keep on the rails.
This also appears to be on a slight downgrade, and if so would add to the momentum of following cars and reduce tension on the couplers at this speed. Less chance of 'holding them down' by that.
btw, re: 'tension' .. this is a familiar scenario to RR modelers/players like myself. And conversely, with heavy rolling stock and tight track radii one learns to put heavy cars in the front of a consist. With them in the back coupler tension can cause light cars (IE: empty, flat) in the middle to fall inward on a curve. Banking from the rear or middle of any consist vs engines all up front considers this. (you knew that
