Working rail roads and their tracks.
   / Working rail roads and their tracks. #1,641
I see Amtrak shut down the Acela yesterday on the north-south trackage because of the heavy snow and curtailed other passenger service in the NE. Don't believe that have the snow removal equipment like Flangers or plows out east to remove it from the tracks.
Kind of like salt shakers and plows in Atlanta.
   / Working rail roads and their tracks. #1,642
They have flangers and plows, they only problem is they are not everywhere at once, and they do not have enough of them.
The two Beilhack railway snow clearers models being the self propelled HB1000S and self propelled HB900S inherited from the CONRAIL Massacre are the primary snow clearing machines used by CSX as flangers and rotary snow plows over the entire CSX system as they have flange plows mounted on both of the snow clearers frames.
The HB1000S and the HB900S have the ability to elevate themselves using the integral hydraulic hoist system mounted in the center of each machine using a very large landing pad that is lowered to the rail ties and pushed the entire machine upward so that the internal turntable mechanism can rotate the machine and then the snow clearer is lowered to the rails and the landing pad is fully retracted into the frame of the railway snow clearer and the snow clearer can travel in the opposite direction without the need for switching to a siding track to reach a turntable, balloon track or WYE to change directions.
Both machines have 3 Mercedes Benz V 12 torbocharged and after cooled diesel engines to provide power to the VOITH hydrostatic transmissions used to power the twin snow clearing heads and the 4 axles in the two sets railway trucks under the snow clearers upper frame.
Both machines have to be towed from the rear for long distance travel by an MOW engine and then uncoupled to do snow clearing in order to reach the locations requiring snow clearing faster due to frieght traffic that may be on the lines as the MOW department is only allowed on the lines when repairs/snow clearing are needed.
They painted both of them that ghastly fluorescent CSX MOW lime color UGGGGLLLLYYY.
The HB1000S was a painted with a beautiful Beilhack yellow and the HB900 was painted with a gloss red from the Beilhack assembly shop in Germany in 1976.
I have pictures taken by others of the CONRAIL HB100S machine with a hydraulic powered chute attachment and a representative HB900S machine in use in Switzerland on one of the Bernina narrow gauge lines with an electric B power unit coupled to it.
I still cannot fathom how BNSF did not scrap the GN rotary plows they inherited and invested in 4 Beilhack machines to replace them or how Union Pacific rebuilt the rotary plows they have when they could have had a self propelled multipurpose machine that does not require 2-5-6 locomotives to power them to clear flangeways and also work as rotary plows at the same time; I just shake my head in disgust as the HB1600S machines can clear much over 22,000+ tons per hour of heavy snowpack on the first pass and then clear the right away on the second pass to a width of over 15 feet.
What a bazaar looking contraption!
   / Working rail roads and their tracks. #1,644
Video of when rotaries were fired up 10 yrs ago before flanging and spreading in the deepest snows. btw, I have a DVD that I can take a screenshot from to show how the snow sheds on the pass have 'shrunk' over the decades since modern equipment has replaced crews shoveling by hand.
   / Working rail roads and their tracks. #1,645
Hello Arly,
When MArtin Beilhack patented his first railway snow clearer in 1952
he accomplished a world changing method of snow removal on railroads.
As of today there are at least 53 of these Railway snow clearers used worldwide
most of them are in europe and have replaced almost all of the rotary snow plows
that have been in use. The few that are left are museum pieces that may be brought
out on occasion and a couple more rotary plows in the old eastern block countries.
In the first image the HB1600S model has the moldboards fully extended outward
and the discharge chutes pointed to the full left position and full right position.
The chutes can also discharge the snow forward with these chutes and spouts.
There are two gear driven snow and ice breaking propellers in front of the discharge chutes.
They spin to break up deep snowpack as the as the snow and ice breaking propellers mounted in front of the snow
clearing discs on extendable arms that rotate at the same high rate of speed breaking the snow and ice
into the smallest portion. This allows the 4 scoops on each snow clearing disc which are rotating in
opposite directions to scoop up the broken snow and ice and throw it up and out of the chute and spout
at high speed and volume as shown in image 11380. In images 68129 and 68126 you can see the snow
clearing heads have been moved outward with the double acting slide cylinders to clear the right of way to the full
fifteen foot width.
Here are few photo images to show you how the snow clearing heads work with them fully extended.
   / Working rail roads and their tracks. #1,647
Lol, guy just keeps plowin.
   / Working rail roads and their tracks. #1,648
Nothing he could do,so back to work.
   / Working rail roads and their tracks. #1,649
I’d probably be in a bit of a state of shock and take a break if that happened right next to me.
Ahahahahahaha
   / Working rail roads and their tracks. #1,650
Cleanup of the derailment above.
Bruce
2006 GMC C5500 BUCKET TRUCK (A59905)
2006 GMC C5500...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
