radius cut smoothing
/ radius cut smoothing #21
clean your tip and set the regulators until you have a 12 inch long feather when you pull the O2. It needs to be fine and long.
I'm about one step above a hack when it comes to torch work, but this is how I set my torch to cut. In my opinion cutting with a torch is just like welding with a Mig welder, you have to find that sweet spot. Most people push the oxygen lever all the way down. Every torch is different but I generally find the sweet spot by only pushing the oxygen lever an 1/8 to 1/4 inch.
/ radius cut smoothing #22
Even cutting something like that in that thick of steel with my plasma cutter will leave some beveling that would need cleaning up with a dremmel tool.
Plasma swirl patterns create different bevels whether going clockwise or counter-clockwise. Not a big issue to clean up though.
Now if you really want a clean cut...bundle up a few Million $$ and get yourself a nice laser cutter cnc...HA:laughing:
2019 KENWORTH T680 (A67714)
2019 KENWORTH T680...
More Info coming soon (A66738)
More Info coming...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2014 FORD F-150 (A67714)
2014 FORD F-150...
UNKONW  TRIAXLE ALUMINUM VACUUM TRAILER (A67714)
UNKONW TRIAXLE...
