radius cut smoothing
/ radius cut smoothing #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
What is a good tool to smooth out a 1 1/8" inside radius cuts made with a torch in 3/8 metal plate? Hand filing is getting old rather quickly. Do not have a drill press able to handle this diameter.
/ radius cut smoothing #3
I agree with the roto Carbide burr. Double cut. Next would be a flap wheel on the die grinder.
Went to Lowes and picked up this Kobalt tool as it was the only rotary tool I could find there. It worked best at slow speed in a variable speed drill. Took about 5 minutes so its slow but gets the job done. As they are only about 4 bucks, I could by several to finish th job. They also work plastics and wood of course.
Thanks for your advise.
/ radius cut smoothing #6
If I want it smooth I use a drum sanding roll.
Bill
/ radius cut smoothing #7
I guess I have a long way to go cutting with the torch, my cuts look too jagged to be useful. I stopped cutting with the torch and find some other way.
/ radius cut smoothing #8
Making a template to help guide the torch will smooth up the cut a great deal as compared to hand held torch, unless you have a very steady hand.
/ radius cut smoothing #9
Five minutes doesn't seem slow to me, for what you're grinding there. What are you making, a quick-hitch?
5 minutes was to finish up the hack job I did with the file which did most of the rough work. (over a half hour) They are brackets to go on top of a loader bucket to hold bar type forks. This way I can load and unload the forks w/o getting off the tractor as I have only a pin type mount for the bucket. The torch was used only for the radius as I could not get in there with the sabre saw. The right drill press would have eliminated this problem all together.
/ radius cut smoothing #11
That looks like plasma cutting territory, you should get Mark away from his BBQ long enough to give you a quote :laughing:
I have a pin on bucket too, and the more I hear about the QA problems, the gladder I am. That looks like a good idea you've got there.
/ radius cut smoothing #12
I would have likely wore through it with a hole saw. Seeing as I have the torch skills of an Orangutan...:D
A holesaw? They have that for metal this thick? When at Lowes, I did see this drill attachment that had 4 carbide teeth welded to a collar. Didn't know what it was for but it looks as if a good drill press was needed.
/ radius cut smoothing #14
/ radius cut smoothing #15
The best tool for that is a high speed die grinder with a carbide burring tool. I have several of different configurations and diameters that I use with my high speed drills since I burned up my die grinder and havent replaced it yet. They work best at high speeds and light pressure rather than the low and medium speed with likely lots of pressure as you were using on the drill. Since my die grinder burned up, I havent found enough instances of needing it to replace it. Maybe Harbor Freight will have one on sale soon.
/ radius cut smoothing #16
Grizzly has a few, I just ordered an 'industrial' one :laughing: for $19.
/ radius cut smoothing #17
I bought a CH one at home depot. It works great, but I later found out that that harbor freight and princess auto have the same one for way less.
/ radius cut smoothing #18
/ radius cut smoothing #19
torches still work, just get some more practice. Most people just fire up and cut the steel. But for finer work try this
- Grind the scale off the front and back
- Remark and even set some punch marks for following your line
- clean your tip and set the regulators until you have a 12 inch long feather when you pull the O2. It needs to be fine and long.
- Use a good clean dark lens
- Lots of Pre-heat, and then some more.
- Get comfortable at the END of your cut and then move to the start of your cut. You will always cut better moving TOWARDS your comfort zone.
- They sell nice radius cutters that hold the torch and guild it. The better ones set to a punch hole and use a magnet
The torch set up has been around a long time and is still in every shop in the country. It works.
Good luck,
/ radius cut smoothing #20
Good luck,
that one sounds like it's worth the price of admission right there.
2015 Ford Explorer AWD SUV (A66738)
2015 Ford Explorer...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
2009 BETTER BUILT PH2322DT-E TRAILER (A66091)
2009 BETTER BUILT...
2022 CATERPILLAR 299D3 SKID STEER (A65056)
2022 CATERPILLAR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2023 CATERPILLAR 289D3 SKID STEER (A65056)
2023 CATERPILLAR...
