Radiator Hunt - MT2001FD
/ Radiator Hunt - MT2001FD #1
Mitsubishi MT2001D
Mitzie (Mitsubishi MT2001FD) was my Late Husband's tractor and I have tried to maintain her ... she works hard around my place, but I am not sure I take good enough care of her.
My Mechanic is not a fan of grey tractors, but he works on her with minimal fuss
He had her in the back pasture spraying (I just got a 65 gal Fimco 3pt sprayer) and Mitzie overheated.
She has done this for years ... I know about how much and how long before my light comes on, so everything is done in stages.
I have called Steven's, Weaver, Pitt, and All-States ... all a firm "No!". Southern Global was also a no, but rude about it.
I have left a message with Schaeffer's, and followed it up with an email.
Two questions ...
Have I missed any sources (Yes, I have down loaded the PDF, which is amazing)??
And ....
Can the radiator be cross referenced?? That cannot be the only tractor that radiator ever went into.
Thank you so very much!!!
Anne
/ Radiator Hunt - MT2001FD #2
Two questions ...
And ....
Anne
Anne,
Glad you downloaded the PDF. We try to keep it up-to-date.
Len Schaeffer should find something. He's good at it.
You could reach out to Pitt Auto. They do Gray machines too. Not certain of their pricing.
Mitsubishi Tractor Parts
Now, the MT2001 is related to the Satoh S670. If I do a search on the S670, I find radiators. You need to compare your broken one with the S670 to verify.
/ Radiator Hunt - MT2001FD #3
The tractor is old enough you could probably have the radiator professionally cleaned. I think they take it apart and clean the core with rods or something like that. You could even have the core replaced at a radiator shop, we have one locally that does all of that.
/ Radiator Hunt - MT2001FD #4
It is harder to find radiator repair places anymore. Glad you have one in town.
Plenty of these Japan made tractors use Japan radiators found in Japan mini-trucks and such. It would be nice to know what cross references these.
Anne,
Pitt was a NO when I called ... and Mr. Scheaffer has not called back yet.
Wonderful info on the S670! I thought there had to be a relative somewhere! :)
/ Radiator Hunt - MT2001FD #6
Hoping you downloaded the PDF pinned at the top of the thread. When you search for your machine, you will turn up machines with the same engine and size. Much of the time these will use the same radiator and such.
Downloaded, yes ... actually read and took notes, no
I was after the last page and the parts info :)
I'll go back and really study!!
/ Radiator Hunt - MT2001FD #8
I had one but sold it . After doing more research. I found one from a different model that I have that fits
/ Radiator Hunt - MT2001FD #9
Two questions ...
And ....
Anne
try a Mitsubishi tractor dealer in the Netherlands. I talked to them 2 yrs ago while looking for a obsolete radiator for my Japanese international tractor that was built by Mitsubishi. the radiator matched up to the measurements and specifications and the brand new radiator was only $350 thats including shipping & Vats. they would be able to cross your model over to correct part # since it's a Mitsubishi tractor, they are still using the radiator that fits mine in brand new tractors but there was no part # interchange for it..
/ Radiator Hunt - MT2001FD #10
As Roadworthy said, find a local radiator shop, and have it looked at, and/or recored. A good radiator shop can do amazing things, and can rebuild just about anything. Looking for a used or New Old Stock replacement will take you a lot time and effort. You wouldn't know if a used one is functional anyway. A recored one will be flushed and pressure tested. And this also maintains the local economy.
/ Radiator Hunt - MT2001FD #11
yes,they can. while I had my obsolete radiator in a radiator shop I researched and found new ones were cheaper in the Netherlands. too late, I called to cancel the job and it was already completed, repaired the smashed bottom tank and a recore, cost me a little over $1000. and it was for my 18hp international 234
/ Radiator Hunt - MT2001FD #12
Robbins Radiator Works in Daytona Beach can recore yours if your tanks are good, top bottom and sides. Old school craftsmanship still in business doing the nasty work with lead and acid. Its worth it. Just two days and mine was done for my MT 372 D I sent a branch through four for five verticals. I found ONE new in box some one wanted 1700 for, they probably still have it, and always will. Ill drive to a big metroplitan area and find an old school Rad shop to repair, before I pay $1700, and laugh all day at their ****ty attitude over the phone. I could buy trinkets ans small parts from them fr my gir if I wanted to, but- piss on them- I do give my business to Valley Power in Roanoke if I need something, and they have it.
/ Radiator Hunt - MT2001FD #13
I had a Satoh Beaver and finally broke down and pulled the radiator off. Called a reputable radiator shop that was 60 miles away and took the radiator. A week later they called and said it needed to be rebuilt. They sent it off for 3 weeks to another shop. It ended up being $300 but was just like a new radiator. My tractor no longer runs hot when loading it down bush hogging. They recorded the radiator. I’m in South Carolina.
/ Radiator Hunt - MT2001FD #14
they had to repair my bottom tank,a stump crushed it and split it. still more then what it should have been. no one in the USA had a rebuilt or new radiator for it.could not find anything by the international part #. I finally surfed by the pic of mine and all dimensions including mounting holes, neck size and position, found one after 3 weeks of surfing in the netherlands. Mitsubishi built these international 234's for international, mitsubishi is still using these same radiators in new mitsubishi tractors. it would have been $350 with vats and international shipping from the dealer in the Neatherlands. I checked with the radiator shop and they just finished mine so I was too late. had to pay the $1000. I did get the mitsubishi part # for the radiator and shared it in the archives of tractorbynet
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2019 Ford F-450XL (A60462)
2019 Ford F-450XL...
