Radiator hose "snapped"
/ Radiator hose "snapped" #81
It's not worth the risk of over heating your machine by having the repair give away while you are working away from the house.
/ Radiator hose "snapped" #82
You'll NEVER clean it good enough for any kind of "glue", including JB. A radiator shop may be able to "weld" it, but I doubt it. A new one is in order, I believe.
I've fixed them. Not saying it's my first choice. But sand it, carburetor cleaner the area, burn with propane torch, wire brush it off, she be clean for epoxy.
/ Radiator hose "snapped" #83
I bought a plastic welder. It works good on those projects.
/ Radiator hose "snapped" #84
Not only that a radiator is under pressure not like a plastic jug with just fuel sitting in it.
/ Radiator hose "snapped" #85
I was thinking the tapping idea....not sure how that would work in the radiator as it "seems" to be plastic, at least at that connection point. New OEM radiator = $1000...Bobcat is crazy, but I might be stuck. I'll pull the radiator and see what I'm working with...maybe a shop has some ideas then again, need to find a radiator shop near me, lol.
Thanks all
I'd measure the size of the radiator and try to find one in a junk yard. Some of the smaller cars should be close to the same size. Just check inlet and outlet positions and try to find a metal one. Junk they make now days....another reason to buy old.
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
UNUSED KJ K2512 - 25' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K2512 -...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
