Radiator hose "snapped"
   / Radiator hose "snapped" #81
It's not worth the risk of over heating your machine by having the repair give away while you are working away from the house.
   / Radiator hose "snapped" #82
You'll NEVER clean it good enough for any kind of "glue", including JB. A radiator shop may be able to "weld" it, but I doubt it. A new one is in order, I believe.
I've fixed them. Not saying it's my first choice. But sand it, carburetor cleaner the area, burn with propane torch, wire brush it off, she be clean for epoxy.
   / Radiator hose "snapped" #83
I bought a plastic welder. It works good on those projects.
   / Radiator hose "snapped" #84
Not only that a radiator is under pressure not like a plastic jug with just fuel sitting in it.
   / Radiator hose "snapped" #85
I was thinking the tapping idea....not sure how that would work in the radiator as it "seems" to be plastic, at least at that connection point. New OEM radiator = $1000...Bobcat is crazy, but I might be stuck. I'll pull the radiator and see what I'm working with...maybe a shop has some ideas then again, need to find a radiator shop near me, lol.
Thanks all
I'd measure the size of the radiator and try to find one in a junk yard. Some of the smaller cars should be close to the same size. Just check inlet and outlet positions and try to find a metal one. Junk they make now days....another reason to buy old.
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
Polaris Side by Side (A50324)
Polaris Side by...
2757 (A55787)
2757 (A55787)
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
