Radiator hose replacement
/ Radiator hose replacement #11
In 21 years and 415,000 KM I've replaced my lower ones(2) twice while changing water pumps because they are very difficult to do with the pump in place. I patched the top hose with tape when it leaked at about 350,000 KM and then changed it when it was convenient
/ Radiator hose replacement #12
Wife's '99 Explorer has 185k on it, original hoses. I replaced the Serp belt around 80k, and I think it could stand to be replaced again. I check the hoses every now and then. No bulges or cracks, still soft and pliable. If you want the peace of mind, go swap them, but I'd say you are no where near needing to be concerned about it.
'98 Civic 165k and '05 F250 45k are also on original hoses. I did the belts on the civic when I did the timing belt and water pump at 125k when I bought it (interference engine - you don't want the timing belt breaking). Water pump was PM at that age as it is driven by the timing belt so you are right there already, plus if it leaks/seizes, it will take out the timing belt.
2014 New Holland B95C (A60462)
2014 New Holland...
(INOP) 1997 FORD ECONOLINE VAN (A59823)
(INOP) 1997 FORD...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2018 FORD F-150 (A60736)
2018 FORD F-150...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
