QUIK ATTACHMENTS
/ QUIK ATTACHMENTS #1
bjess8
SOUTH CENTERAL ,PA
GRAND L3130
I bought a snow plow from a farmer who used it on a bobcat.Now when I tried
to hook it up to my grand L3130 the pin holes were too close. Would it be ok
if I cut the holes bigger in the plate to make it work?Is this a problem that I will run into alot when i start buying attachments for this machine.I have a bushhog loader m246 with a quik attachment.Will it hurt if I cut the holes too big? thanks for the help
/ QUIK ATTACHMENTS #2
This may help you some, holes have to be just right, to big is not good and too small is not good.
Careful cutting
/ QUIK ATTACHMENTS #3
I have a few older bobcat attachments and the pin holes would not quite line up with my JD quick attachment. The newer bobcat plates have a wider slot like MrJimi shows. You should be able to make the slots slightly wider. I used a reciprocating saw with metal cutting blade to make the slots bigger. I used the blade to cut the top and bottom of the metal slots so they are straight and smooth. Then I used my cutting torch to cut the more vertical remaining edge. A small cut of wheel might be used in place of the torch, if the wheel is small enough.
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
250-bushel Gravity Wagon (A66408)
250-bushel Gravity...
2009 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2009 MAC 35ft...
2021 Chevrolet Traverse SUV (A64557)
2021 Chevrolet...
2022 EZ-GO ELITE...
Beverage Truck Body (A64556)
Beverage Truck...
