Quik attach loader adapter?
/ Quik attach loader adapter? #1
creeper
Amelia Va.
John Deere 790wFEL
I am interested in building additional attachments for my 419 loader.Just wondering if anyone has already done the measuring and planning for the initial mounting plates or if basic mounting plates are available already.To further explain..... at the end of my loader arms, they attach to the bucket with a curved steel bracket up top and a quick pin at the bottom, similar to a tph pin.Once you have an adapter plate made you could add just about anything with a little welding.Any experience with this anyone?If not, I will do the trial and error method and post results later. Thanks for any info. /forums/images/graemlins/tongue.gif
/ Quik attach loader adapter? #2
I have built a FEL forklift and a FEL snowplow for my 410 loader. The hooks and pins are available from JDParts for about $30.00 or so much easier than making your own. I just used 2x2 tubing and 2x3 tubing to make a frame, tacked it up on the loader to keep from having to take measurements.
I detailed the snowplow build in this POST .
It is a very nice setup to work with.
Thanks for the tip. I called the local dealer today,since I didn't have a part # he will fax me a picture of what he thinks I need. Once I get a part# Iwill post it.They seem to be very helpful, I ordered a shim kit for my hyd. relief valve also and they faxed a parts breakdown over without even asking,I was pleasantly surprised.When I get to the actual material list for forks,I may get your opinion on thickness etc. based on your experience so far. /forums/images/graemlins/grin.gif
/ Quik attach loader adapter? #4
Great!
I have the part numbers somewhere around here, if you need me to I will find them JDParts.com for you, that is how I found them.
Please let me know how I can help...
I do not have pics of the forklift (old camera, lost disks...) But can take new ones if you need them.
Kenny
Don't worry about the part # Iwill get it straight with the dealer tomorrow,I could have called them first in hindsight. I really didn't expect them to be available. Alot of companies will hold on to stuff like that,in order to keep there implement sales up.Anyhow,I will be working on it,lots of possibilities.............. I was going to bend metal or cut some pipe etc,but I think this will make a much cleaner job. Btw, I also work for Verizon,formerly a cable splicer,transfered to a building mechanic about 3 years ago. Nothing like tip n ring huh? What a small world. /forums/images/graemlins/grin.gif
/ Quik attach loader adapter? #6
When you get the hook and pin part numbers could you post them? I am thinking about making some quick attach stuff too and the hook and the pin were the few parts that I thought would be a real pain to fabricate.
/ Quik attach loader adapter? #7
Try these part numbers
Hook W43359
Pin w47211
Good luck PeterT
Thank You, those part#'s are good. They list on the heavy duty bucket. The pins are $6.33 ea and the hooks are $12 ea.
/ Quik attach loader adapter? #9
Excellent -thanks. I will go look them up and make sure they were what I was looking for.
/ Quik attach loader adapter? #10
Yep,
Those are the part #'s I used.
W43359 Hook,Bucket $10.18 each
W47211 Pin $6.05 each
Total for the project is $32.46, Much better than trying to fab them yourself!
Prices are from JDParts today.
/ Quik attach loader adapter? #11
KennyD, could you post some pictures of your fork lift attachment?
/ Quik attach loader adapter? #12
Sure,
Hopefully this weekend I can take them for you.
Kenny.
/ Quik attach loader adapter? #13
Your quick attatch doesn't need to be round becauce it is not rotating. I think deere uses 3/16 thick metal. I used a 3/8s piece for the top of my tool bar and cut 2 short pieces off and down to size to make the 2 hooks.
Ordered the parts today $36 total,a little more than deere parts.com,but no shipping.Also picked up shims for raising hydrauli pressure, hope I dont blow anything up. /forums/images/graemlins/shocked.gif
/ Quik attach loader adapter? #16
</font><font color="blue" class="small">( KennyD, could you post some pictures of your fork lift attachment? )</font>
I got home early today, and the sun was shining bright, so I took some pics, I posted them in the Build it Yourself forum, you can view them HERE
Kenny, Those look great.Thanks for the pics.
/ Quik attach loader adapter? #18
nice job
can you give me the size of the top pin that goes in the angle iron
please
/ Quik attach loader adapter? #19
bela_phil said:
nice job
please
Not sure exactly what you are looking for?
/ Quik attach loader adapter? #20
I think he means the top of the mount on your loader that the bucket hook (or angle iron for homemade mounts) hooks over.
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2009 Ford F-550 Versalift Signalier ATR-41 41ft. Bucket Truck (A61573)
2009 Ford F-550...
