Quickie log-drag, (paper-thin MIG weld)
   / Quickie log-drag, (paper-thin MIG weld) #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Heres a quickie logdrag I made because the log was too big for my log-arch. Already had the rear dolly.
   / Quickie log-drag, (paper-thin MIG weld) #2
Looks like that will get'er done :)
Doesn't look OSHA approved, watch out for the black drone helicopters ;) lol
   / Quickie log-drag, (paper-thin MIG weld) #3
Quick, low cost & looks like it works great.
But you have to work on the marketing.
You call it "paper thin weld".
We call it "tripple redundancy saftey welded for your protection - think of the children!".
   / Quickie log-drag, (paper-thin MIG weld) #4
Heres a quickie logdrag I made because the log was too big for my log-arch. Already had the rear dolly. <img src="http://www.tractorbynet.com/forums/files/welding/395670-quickie-log-drag-paper-thin-logdrag1-jpg"/><img src="http://www.tractorbynet.com/forums/files/welding/395671-quickie-log-drag-paper-thin-logdrag2-jpg"/><img src="http://www.tractorbynet.com/forums/files/welding/395672-quickie-log-drag-paper-thin-logdrag3-jpg"/><img src="http://www.tractorbynet.com/forums/files/welding/395673-quickie-log-drag-paper-thin-logdrag4-jpg"/>
Nice job Sodo. Looking forward to seeing what you can do with the rest of the Hyundai. :)
Terry
All this just to save scraping up my picturesque driveway by a log dragging. Log arch maxes out at 16", sawmill maxes at 21", this log is 23" so I'll have to skin it a little to get it into the sawmill, but it's a nice log and I wanted to get it to my pile before the firewood cutters spotted it.
Yup 3x = children are safer for miles around! :laughing:
I'll send a pic of the Hyundai when I get the hood banged out and reinstalled. Wife hasn't noticed it gone yet. :cool:
   / Quickie log-drag, (paper-thin MIG weld) #6
I'm too lazy to 'skid' them. This oak was cut down in my neighbourhood. It was on property slated for a Habitat For Humanity project. They'd throw anyone else in jail if they even asked about cutting it down in this area.
image-3422436055.jpg Terry
   / Quickie log-drag, (paper-thin MIG weld) #7
Please forgive me if this is a stupid question, as I haven't had much experience dragging large logs yet. I've got a biggie I need to move, but just haven't tackled it yet. So here goes....
Couldn't your 3-point just lift up one end of the log? If there is a reason not to do it this way, please educate me! If your 3-point can't lift it, then how did you get the other end onto the dolly? And where can I get a similar dolly?
Thanks,
xtn
I would much prefer that method, but at the time, didn't have a 3-pt attchmt that could lift it. All I have is a back-blade attachment, which extends about 4 feet back. Three-point lift capacity for B2710 is 1,655 lbs, certainly sufficient, I need to build something for that, thanks for the note. Not sure why I haven't built one, it sure would have been useful in this example.
I built the log dolly to be lightweight, to be carried up & down steep hills by hand. I never expected it to have such weight on it. This is a "wet" log, cut a few days prior.
I got it onto the dolly by dragging/rolling the log onto another log. So the log counterweighted itself and I was able to raise the rear half high enough to slide the dolly under the raised log end. Other times I've strapped the dolly onto the log with wheels-up, then carefully rolled the log+dolly over until the dolly was wheels-down. All this is far far beyond the intended capacity of that dolly. It's made with 1.5 x 1.5 x .062 sq. tube steel (16ga). Notice the V-cradle is not even braced. I'm amazed. Harbor freight tires have been the only disappointment, they crack after one year then explode under weight.
More info on the ( Lightweight log Dolly) is here, posted back when emotions ran high :D whenever 120volt MIGS were mentioned.
   / Quickie log-drag, (paper-thin MIG weld) #9
Sodo, I built this one from an abandoned trailer and a few pieces of 2"x2"x 1/4" tube. The log is white Oak and 8.5' It held up quite well although I need a better lifting winch.
(p.s. And I used a 120 volt mig welder to do it)
I bet it was a pretty hard pull to lift that big fella with a foot-long lever!
That arch looks good; I need both lightweight and heavyweight log arches. I'll build one when I run across wheels & spindles. Got far more projects on the list than I have time, but it's good to get some done.
And good to have the tools!:D. And no drones, but they may be more lenient than TBN cops. :D
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
