Quick hydraulic fitting question
/ Quick hydraulic fitting question #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
So, I am adding a ram to the kicker on our baler (so that I can aim where in the wagon the bales land, thread with pictures coming soon) and I bought 2 quick connects, one is a Pioneer VP8010-4 and the other is a Pioneer VP8010-4P, the 4 has a ball on the end to keep the fluid in while the 4P has a poppet on the end (that will teach me to check that all the fittings I buy are the same), are these two compatible? or should I return the 4P one and get a 4 (which will match what is on all of our other equipment)?
Thanks
Aaron Z
/ Quick hydraulic fitting question #2
try both on one of the other implements you have , if it fits it should work, if not the answer is pretty simple. zman
The problem is that if I install I will not be able to return it (ok, I probably could, but I wont). Physically they are the same except that one has a poppet and the other has a ball.
Aaron Z
/ Quick hydraulic fitting question #4
Aaron Z
If the QD will connect up tight, then I believe the poppet and ball are compatible.
I also believe the poppet style has less pressure drop than the ball end type.
http://pdf.directindustry.com/pdf/s...-fluid-transfer-couplings/26066-73880-_2.html
The P in the part number indicates poppet style QD.
/ Quick hydraulic fitting question #5
Although I think they are interchangeable...It would drive me nut's having two different ones-just my personality defect.
/ Quick hydraulic fitting question #6
I agree.. I'd get both the same.. and never wonder about it.
soundguy
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A69167)
2014 FREIGHTLINER...
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A67714)
2013 FREIGHTLINER...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
2009 HEIL CRUDE PUP TRAILER (A67714)
2009 HEIL CRUDE...
JOHN DEERE 6330 TRACTOR (A65057)
JOHN DEERE 6330...
