Quick hydraulic fitting question
/ Quick hydraulic fitting question #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
So, I am adding a ram to the kicker on our baler (so that I can aim where in the wagon the bales land, thread with pictures coming soon) and I bought 2 quick connects, one is a Pioneer VP8010-4 and the other is a Pioneer VP8010-4P, the 4 has a ball on the end to keep the fluid in while the 4P has a poppet on the end (that will teach me to check that all the fittings I buy are the same), are these two compatible? or should I return the 4P one and get a 4 (which will match what is on all of our other equipment)?
Aaron Z
/ Quick hydraulic fitting question #2
try both on one of the other implements you have , if it fits it should work, if not the answer is pretty simple. zman
The problem is that if I install I will not be able to return it (ok, I probably could, but I wont). Physically they are the same except that one has a poppet and the other has a ball.
Aaron Z
/ Quick hydraulic fitting question #4
Aaron Z
If the QD will connect up tight, then I believe the poppet and ball are compatible.
I also believe the poppet style has less pressure drop than the ball end type.
http://pdf.directindustry.com/pdf/s...-fluid-transfer-couplings/26066-73880-_2.html
The P in the part number indicates poppet style QD.
/ Quick hydraulic fitting question #5
Although I think they are interchangeable...It would drive me nut's having two different ones-just my personality defect.
/ Quick hydraulic fitting question #6
I agree.. I'd get both the same.. and never wonder about it.
soundguy
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
10ft S/A Utility Trailer (A66738)
10ft S/A Utility...
2014 Ford F-250 Knapheide Service Truck (A66736)
2014 Ford F-250...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
(INOP) 2006 INTERNATIONAL 7400 DUMP TRUCK (A65057)
(INOP) 2006...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
