Quick Hitch Questions
/ Quick Hitch Questions #61
While weight further back from the tractor provides more fulcrum effect with the counter balance process, never overlook the traction benefits from adding weight at the tires (2 sources-wheel weights and loading tires).
With loaded tires the extra weight is on the ground, the tractor frame only carries extra weight when a wheel leaves the ground. Makes tractor less likely to roll-over. I add the ballast box when I might max out the fel (grapple, tree puller, heavy loose material).
CAT930K (A58214)
CAT930K (A58214)
Bobcat MT85 (A60462)
2019 John Deere 6125R (A60462)
2019 John Deere...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
Railroad Maintenance Machine (A61570)
Railroad...
Iranch IRGC40 (A60463)
